h4life Posted August 10, 2008 Share Posted August 10, 2008 so i went off roading yesterday and had a blast but now im putting out fires haha. on the way home i aquired i thunping noise in what i think is the front driverside. it didnt do it on the way there. only does it under power and in every gear. more so in the 3rd forth. also it comes and goes but pretty much is always there. it dosent click like a cv joint. did i cook it? when its bad it shakes the whole car/truck pretty bad. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 10, 2008 Share Posted August 10, 2008 Yes - you have a bad inner Double Offset Joint (DOJ) on one of your front axles. GD Quote Link to comment Share on other sites More sharing options...
Mikldom Posted August 10, 2008 Share Posted August 10, 2008 if it is real bad and the axles are sound, then you blew the center diff in your transmission. It will be there, and be real bad under power, but still thumping when you push the clutch in. I have had this happen twice, first to my Brat, then to my 84 Wagon. Good thing transmissions are fairly easy to change with 5 or 6 hours and a good jack.. let us know how it turns out.. Quote Link to comment Share on other sites More sharing options...
h4life Posted August 11, 2008 Author Share Posted August 11, 2008 if it is real bad and the axles are sound, then you blew the center diff in your transmission. It will be there, and be real bad under power, but still thumping when you push the clutch in. I have had this happen twice, first to my Brat, then to my 84 Wagon. Good thing transmissions are fairly easy to change with 5 or 6 hours and a good jack.. let us know how it turns out.. it goes away as soon as i push in the clutch. Quote Link to comment Share on other sites More sharing options...
Mikldom Posted August 11, 2008 Share Posted August 11, 2008 Most likely bad DOJ on the inner joint of the CV axle, as others have stated.. that usually clues you in it goes away as soon as i push in the clutch. Quote Link to comment Share on other sites More sharing options...
TeamCF Posted August 11, 2008 Share Posted August 11, 2008 An exact duplicate of what mine did. Bad DOJ / DOJ's. (I blew both on the same trip. ) Quote Link to comment Share on other sites More sharing options...
h4life Posted August 11, 2008 Author Share Posted August 11, 2008 cool. thanx guys. how hard of a fix is this for me not being a guru? and where would i get one? and gone unfixed there will be catastrofic falure wont there. Quote Link to comment Share on other sites More sharing options...
Mikldom Posted August 11, 2008 Share Posted August 11, 2008 It will get to the point of unbearable.. Axle swaps are VERY easy... Most can do them in about 30-60 minutes.. first timers, give yourself 2-3 hours.. You can do this without popping balljoints and tie rod ends if you dismantle all the break stuff, undo the axle nut, take the strut mounts loose and pull the strut out, and stepping on the bottom arm.. don't forget to get the pin out of the axle on the transmission side of the axle.. and whatever you do, don't break off the pin tool in the axle! seriously, they are easy and it is best to just swap the whole axle. cool. thanx guys. how hard of a fix is this for me not being a guru? and where would i get one? and gone unfixed there will be catastrofic falure wont there. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 11, 2008 Share Posted August 11, 2008 You can do this without popping balljoints and tie rod ends if you dismantle all the break stuff, undo the axle nut, take the strut mounts loose and pull the strut out, and stepping on the bottom arm.. Way too much work - pull the inner control arm bolt, and the sway bar link. Two bolts and no stepping on anything. GD Quote Link to comment Share on other sites More sharing options...
GREENSUBIE Posted August 11, 2008 Share Posted August 11, 2008 i lost a tranny mount rubber was gone, it seems similar to what you say? Quote Link to comment Share on other sites More sharing options...
crockettbrat Posted August 11, 2008 Share Posted August 11, 2008 i lost a tranny mount rubber was gone, it seems similar to what you say? It probably what every one else says but also check your sway bar bushings. The sway bar can make a mighty thump when the bushings are gone. Good luck. Daniel Quote Link to comment Share on other sites More sharing options...
