5 lug and Rear disc conversion
Trying to put to gether a shoping list for both a rear disc conversion and a five lug swap
Off the top of my head for the rear disc swap i will need the disc, calipers, mounting for the calipers, and brake lines is there more?
For the 5 lug i'm thinking that i will need the hole rear end, as for the front should i take the hole thing to or do all i need is the 5 lugs and control arms
what else is needed?
In order to do a rear 5lug, you will need XT6 rear calipers, hubs & rotors. XT6's only came with Disk, so if you do a 5lug swap, you have no choice but to convert to disk
Right. the disc swap is acualy for a different car then the 5 lug
The same things you need for a rear 5 lug are the same things you need for a rear disk swap.
Backing plate
Rotor w/hub
Caliper
I pretty much break it all down here:
http://www.ultimatesubaru.org/forum/showthread.php?t=49975
Thats the 4 lug rear disc swap. However, the same applies for 5 lug, just replace with XT6 parts.
For the 5 lug at the front, impreza stuff fits if you replace the top mount on the strut. All you need from an XT-6 at that point is the lower control arm, both sides.
The advantage of using impreza struts and hubs is that you get a camber adjust that the XT-6 did not have.
You have to use impreza Fwd axles, but its worth it (these axles fit the D/R tranny, for the turbo tranny the regular Awd axles should work)
my '92 legacy tophats fit fine on my loyale....
also, with EJ front suspension, you get better brake and suspension options. although you loose the front parking brake (you can convert to the rear. I have a write-up in the USRM about using Nissan rear calipers).
