September 4, 200817 yr Anyone have a good front shot of an ea-82 showing a good view of pulley and adjuster placement? I got a little brain dead after taking mine apart last week and good use a little visual guidance. Thanks
September 4, 200817 yr What Pully and Adjuster? Crank pully and T-belt tensioners? If so I've got a pic that might help. Hope it helps, Tom
September 5, 200817 yr Author What Pully and Adjuster? Crank pully and T-belt tensioners? If so I've got a pic that might help. Hope it helps, Tom Great. Much thanks:)
September 5, 200817 yr Damn that thing's shiny Tom!! LOL Looks better with the new oil pump.. And I like driving more with new T-belts and Cam carriers seals (No worries) Thanks Dave! Pierman2, Your welcome!
September 16, 200817 yr you better go run it through some mud with the covers off. that engine is waaayy to clean
September 17, 200817 yr you better go run it through some mud with the covers off. that engine is waaayy to clean Hahaha theres an idea!! Taking the outer covers off is a joke, you have to remove the oil dip stick to take off the middel cover But all is good.. I want a logging road to drive on!!! (Drool) I want Mudd!! I want a dirty soob Hahaha.
