ea81 oil pan notching?
anyone have any pics handy of the bottom side of the block with the pan gone? I've got a short block at home, but no access to it for a bit.....
might need to do some notching to the rear of the drain plug...
He is running straight axles close to the chassis, the diff will hit the oil pan under flex.
Just Beat it with a 10 lb sledge :banana:
-Bill
-Bill
10 pounder would smash it like a beer can. Just install it and do a little wheeling for self clearance.
i don't know if this has enough detail or the right angle for what you need but its what i've got. its a solid lifter block.
17-strippedunderside.jpg?t=1229474000
I could take pics of the stripped block you gave me, or let you borrow it for a while
could also take pics of ea82 - and oil pan
