AT rear Axles to D/R rear axles
Are the AT axles different in the rear then push button or D/R rear axles. I know that the fronts are different but was wondering about the rears, if they where 25 spline too, in stead of 23 spline
Jeff
I believe all EA82 rear axles are the same. As with all EA81s are the same. But you can't swap EA81 to EA82 or vice-versa.
Sorry I should have added that it was for an EA82.
Jeff
Johnson;777733']I believe all EA82 rear axles are the same.
just for clarification.....they're not all the same ('85-'86 had DOJs on the outside, others had CVs, and there may be shaft diameter changes). BUT, they are completely interchangeable. length, and spline count on both ends are the same.
unless i'm missing something, that's not true for EA82's. the only difference that doesn't allow them to interchange on the front is the spline count on turbo and non-turbo axles. otherwise all fronts are interchangeable between auto/manual and left/right.
That's what I was getting at. But it is good to know the fact that older ones had a DOJ.
...front is the spline count on turbo and non-turbo axles. otherwise all fronts are interchangeable between auto/manual and left/right.
True.
Johnson;777948']That's what I was getting at. But it is good to know the fact that older ones had a DOJ.
yep, I know. and in this situation it doesn't really make any difference. but for future reference.....a little clarification.
