vincentmoy Posted January 16, 2009 Share Posted January 16, 2009 I was trying to decode my check e lite on my 93 loyale. I unscrew the panel under the steering and found this. I'm not sure where the LED lite is or is it the ECU @ all. Thank you in advance! Quote Link to comment Share on other sites More sharing options...
Cougar Posted January 16, 2009 Share Posted January 16, 2009 Yes that's it. The LED may be on the opposite end of the connectors. Quote Link to comment Share on other sites More sharing options...
vincentmoy Posted January 16, 2009 Author Share Posted January 16, 2009 so I need to unhook all the wires to get the error code? How that works? Vincent Quote Link to comment Share on other sites More sharing options...
Cougar Posted January 16, 2009 Share Posted January 16, 2009 You may need to disconnect the connectors to lower the unit down but they need to be connected to show the error code. There should be just a few screws holding the unit in place. Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted January 16, 2009 Share Posted January 16, 2009 led should be at the "top" end of the silver box, towards the steering wheel push the big bundle of wires out of the way, trun key on and look for flash looks nothing like the old style '86 box Quote Link to comment Share on other sites More sharing options...
hooziewhatsit Posted January 16, 2009 Share Posted January 16, 2009 led should be at the "top" end of the silver box, towards the steering wheelpush the big bundle of wires out of the way, trun key on and look for flash looks nothing like the old style '86 box correct. Once you know where the light is, you won't need to remove the kick panel to check it. You just need to look straight down the steering column to see it. Quote Link to comment Share on other sites More sharing options...
vincentmoy Posted January 16, 2009 Author Share Posted January 16, 2009 That is what my chilton said too... but I just can't find the LED... I have looked around, pushed the wires aside and stuff and it just doesn't seems to be there Quote Link to comment Share on other sites More sharing options...
vincentmoy Posted January 16, 2009 Author Share Posted January 16, 2009 That is what my chilton said too... but I just can't find the LED... I have looked around, pushed the wires aside and stuff and it just doesn't seems to be there. I turn the key to on and expect I'll catch some fleshing light but nope... nothing happen as far as I can see. Anyone can upload a pic of where it suppose to be? Quote Link to comment Share on other sites More sharing options...
Gloyale Posted January 16, 2009 Share Posted January 16, 2009 There is a hole in the front of the unit. Front being the skinny face that is closest to the driver. The light is kinduv down inside the hole. Look harder, it is there. If it isn't lighting at all, you have a lack of power to the ECU. Quote Link to comment Share on other sites More sharing options...
Skip Posted January 16, 2009 Share Posted January 16, 2009 to follow up what Gloyale says this light is also known as the oxygen monitor light It is right where he says. This is an older unit but the light hole should be the same. You might want to plug together your green connectors by the drivers side hood hinge This will make the light flash. Key must be in the run position for it to flash. Quote Link to comment Share on other sites More sharing options...
vincentmoy Posted January 17, 2009 Author Share Posted January 17, 2009 to follow up what Gloyale saysthis light is also known as the oxygen monitor light It is right where he says. This is an older unit but the light hole should be the same. You might want to plug together your green connectors by the drivers side hood hinge This will make the light flash. Key must be in the run position for it to flash. Run position, but does the Eng needs to be running too? Quote Link to comment Share on other sites More sharing options...
Skip Posted January 17, 2009 Share Posted January 17, 2009 no, do not start the engine Quote Link to comment Share on other sites More sharing options...
