January 26, 200917 yr I'm thinking I want to use a big-rump roast drill bit to bevel the holes in some wheels I drilled. I used a 35/64 drill bit for the hole. Is there an optimal drill bit size to use to bevel the edges so the lug nuts seat properly? Thanks. Jacob
January 26, 200917 yr what is the diameter of the lugnuts? Thats the diameter of the drill bit you need.
January 26, 200917 yr Most drill bits have an inclusive angle of 118* or 59* off the center line. You should find out what angle your lug nuts have and buy a countersink to match that. If you can't find what you need locally, you can get it at Mcmaster.com Good Luck!
January 26, 200917 yr I'm thinking I want to use a big-rump roast drill bit to bevel the holes in some wheels I drilled. I used a 35/64 drill bit for the hole. Is there an optimal drill bit size to use to bevel the edges so the lug nuts seat properly? Thanks. Jacob 60 degree point
January 26, 200917 yr "coutersink".it is an actual bit......like 10 bucks for a nice one of machine tool quality from our local supplier.called bixby tool.cheers, brian
January 27, 200917 yr Or you put a tapered stone in your die grinder and go to town like I did. I just always tightened the two origional holes firest and then cranked down the "custom" hols. Nevar had a wehel come off. Course mine wer steel, don't know if youre doing aluminum ones.
January 27, 200917 yr I just always tightened the two original holes first and then cranked down the "custom" holes +1 ... never had a problem. Although if i were to drill a new set, i'd do it the right way for peace of mind.
January 27, 200917 yr 60 degree point "coutersink".it is an actual bit......like 10 bucks for a nice one of machine tool quality from our local supplier.called bixby tool.cheers, brian +1 Jeff
February 2, 200917 yr Author I'm thinking I may just want to use some kind of washers and flat bolts, rather than 60 degree lug nuts. Has anyone tried that method? I guess drag racers do something like that. Jacob
February 2, 200917 yr Someone will correct me if I'm wrong, but I believe there are two ways of centering wheels, hub-centric which are centered by sitting on a boss (raised portion) on the hub, and centering by tapered lug nuts which center around the stud. If you use flat head nuts and washers on a non hub-centric wheel/hub setup, you won't be able to get your wheel centered properly which will both ride rough and probably loosen up and want to fall off. Will-
February 2, 200917 yr Author Someone will correct me if I'm wrong, but I believe there are two ways of centering wheels, hub-centric which are centered by sitting on a boss (raised portion) on the hub, and centering by tapered lug nuts which center around the stud. If you use flat head nuts and washers on a non hub-centric wheel/hub setup, you won't be able to get your wheel centered properly which will both ride rough and probably loosen up and want to fall off. Will- Keep in mind that two of the holes are still original, and I can use regular tapered lug nuts for those two holes. Do you think that would be enough? These are for rallyx only, so I'll be driving about 3 minutes at a time, max. Jacob
February 2, 200917 yr If you're really driving only 3 minutes at a time, then my guess would be it won't be a problem. But I should follow that up by saying that I don't know squat about rally x so you should seek some other opinions. Good Luck! Will-
February 4, 200917 yr Author If you're really driving only 3 minutes at a time, then my guess would be it won't be a problem. But I should follow that up by saying that I don't know squat about rally x so you should seek some other opinions. Good Luck! Will- Bump for other opinions. Can I use washers and flat lugnuts instead of bevelling? Thanks. Jacob
February 4, 200917 yr why are you so opposed to beveling?it is really easy, cheap , and a good bit of insurance for you and your rally-x car.... which by they way is going to be taking a beating in those three minutes..........as you know. you are not drag racing,you are rally crossing. i don't think the flat washers would pass tech anyway.cheers, brain
February 4, 200917 yr Author why are you so opposed to beveling?it is really easy, cheap , and a good bit of insurance for you and your rally-x car.... which by they way is going to be taking a beating in those three minutes..........as you know. you are not drag racing,you are rally crossing. i don't think the flat washers would pass tech anyway.cheers, brain I'm not opposed to bevelling, I just don't want to remove any more metal from a wheel than I have to. Your point about tech is a good one, however. I may end up ordering a countersink later today. Jacob
