security light blinking contantly!
Last year when I bought my WRX, it had a bad alternator, and had to be replaced of course. After it was replaced, I noticed that the security light in the dash blinks constantly. Is there anyway to reset it, or have it only blink when the I lock the car ?
I would disconnect the positive side battery cable for about 15 to 20 minutes, then reconnect, and hopefully the reboot will solve the problem.
[...] I noticed that the security light in the dash blinks constantly. Is there anyway to reset it, or have it only blink when the I lock the car ?
Is there a particular pattern to the blinking (x number of blinks, pause, etc.)?
See: http://www.cars101.com/subaru/keyless.html
i would try something else first. try locking and unlocking several times from the inside with the door closed.
or
look for a push button under the dash, press and hold with the key in each position.
or
i guess you have already tried using the remote.
if i disconnect my battery, it reads that as a security issue and turns off my ignition. i'd like to disconnect mine since i don't have a remote, but unless i paid the dealer to do it i'm concerned that i'll disable my car altogether.
i wish the light on m SVX would blink. Instead its solid, which means need to replace module, $$$
I have it out of the car, trying to see if it will reset, but all i keep reading says solid light is doom. Newer modules were fixed, mine looks like it has a revision printed on it, but ...blah
there is about a second between blinks. I think I am going to try the sugesstions on the link that OB99W gave me....I'll let you guys know what happens.
:grin:
Sounds like the classic SLOW 4way blinking.
Never quite understood is since the car will start and drive.
That cars101 link should tell you how to reprogram/reset the security system.
First WIND WINDOW DOWN - yes I've locked myself out a few times doing this. Part of this is that it cycles the locks.
Second I'd get the car in the air - even ramps. They purposely bury that black button under the dash if it's like the late 90's Legacy's. You'll need a light at well.
Security system is in Valet mode - push unlock on fob - open drivers door - hold unlock button on fob until light stops flashing
Hope that helps
SEA#3
Hope that helps
SEA#3
I saw that on the cars101 link that I got from OB. Tried it as soon as I got off work and went out to the car...SUCCESS!!!!! :banana:
The light is gone!! YESS!!! Thanks everyone for the help :grin:
