my03suby Posted February 17, 2009 Share Posted February 17, 2009 Last year when I bought my WRX, it had a bad alternator, and had to be replaced of course. After it was replaced, I noticed that the security light in the dash blinks constantly. Is there anyway to reset it, or have it only blink when the I lock the car ? Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted February 17, 2009 Share Posted February 17, 2009 I would disconnect the positive side battery cable for about 15 to 20 minutes, then reconnect, and hopefully the reboot will solve the problem. Quote Link to comment Share on other sites More sharing options...
OB99W Posted February 17, 2009 Share Posted February 17, 2009 [...] I noticed that the security light in the dash blinks constantly. Is there anyway to reset it, or have it only blink when the I lock the car ? Is there a particular pattern to the blinking (x number of blinks, pause, etc.)? See: http://www.cars101.com/subaru/keyless.html Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted February 17, 2009 Share Posted February 17, 2009 I would disconnect the positive side battery cable for about 15 to 20 minutes, then reconnect, and hopefully the reboot will solve the problem. i would try something else first. try locking and unlocking several times from the inside with the door closed. or look for a push button under the dash, press and hold with the key in each position. or i guess you have already tried using the remote. if i disconnect my battery, it reads that as a security issue and turns off my ignition. i'd like to disconnect mine since i don't have a remote, but unless i paid the dealer to do it i'm concerned that i'll disable my car altogether. Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted February 17, 2009 Share Posted February 17, 2009 i wish the light on m SVX would blink. Instead its solid, which means need to replace module, $$$ I have it out of the car, trying to see if it will reset, but all i keep reading says solid light is doom. Newer modules were fixed, mine looks like it has a revision printed on it, but ...blah Quote Link to comment Share on other sites More sharing options...
my03suby Posted February 17, 2009 Author Share Posted February 17, 2009 Is there a particular pattern to the blinking (x number of blinks, pause, etc.)?See: http://www.cars101.com/subaru/keyless.html there is about a second between blinks. I think I am going to try the sugesstions on the link that OB99W gave me....I'll let you guys know what happens. Quote Link to comment Share on other sites More sharing options...
davebugs Posted February 17, 2009 Share Posted February 17, 2009 Sounds like the classic SLOW 4way blinking. Never quite understood is since the car will start and drive. That cars101 link should tell you how to reprogram/reset the security system. First WIND WINDOW DOWN - yes I've locked myself out a few times doing this. Part of this is that it cycles the locks. Second I'd get the car in the air - even ramps. They purposely bury that black button under the dash if it's like the late 90's Legacy's. You'll need a light at well. Quote Link to comment Share on other sites More sharing options...
sea#3 Posted February 18, 2009 Share Posted February 18, 2009 Security system is in Valet mode - push unlock on fob - open drivers door - hold unlock button on fob until light stops flashing Hope that helps SEA#3 1 Quote Link to comment Share on other sites More sharing options...
my03suby Posted February 18, 2009 Author Share Posted February 18, 2009 Security system is in Valet mode - push unlock on fob - open drivers door - hold unlock button on fob until light stops flashing Hope that helps SEA#3 I saw that on the cars101 link that I got from OB. Tried it as soon as I got off work and went out to the car...SUCCESS!!!!! The light is gone!! YESS!!! Thanks everyone for the help Quote Link to comment Share on other sites More sharing options...
