Will these wheels fit?
They will clear if:
a) your brake pads are worn down really really far...
B) you grind off alittle of your brake caliper.
Other than that, no.
Would this grinding be dangerous? IE its a daily driver :)
It depends.
After doing some measuring of the wheels in question and a set of EA82 alloys (Yes, I have a pair of them), there is a 1in difference of the inside diameter.
The wheel offset is totally different also, altho I dont know if this would make a difference or not.
Offset for the old alloys is 3.5in and the EA82 alloy is 5.25in.
So, depending on how you feel grinding a 1/2in off your calipers will decide whether you want the wheels bad enough.
Not many have done it, but I havent done a search about it either.
Yeah I wouldnt do it either.
I have heard of others doing it. Its been a long time.
I only know about the brake pad thing because I once owned a EA82 that came with EA81 wagon wheels on it. They worked fine, but then I did a brake job and once I replaced the pads the wheels wouldnt move.
