March 31, 200917 yr Will these wheels http://www.ultimatesubaru.org/forum/showthread.php?t=96888 fit my EA-82 wagon?
March 31, 200917 yr They will clear if: a) your brake pads are worn down really really far... you grind off alittle of your brake caliper. Other than that, no.
April 1, 200917 yr Would this grinding be dangerous? IE its a daily driver It depends. After doing some measuring of the wheels in question and a set of EA82 alloys (Yes, I have a pair of them), there is a 1in difference of the inside diameter. The wheel offset is totally different also, altho I dont know if this would make a difference or not. Offset for the old alloys is 3.5in and the EA82 alloy is 5.25in. So, depending on how you feel grinding a 1/2in off your calipers will decide whether you want the wheels bad enough. Not many have done it, but I havent done a search about it either.
April 1, 200917 yr Yeah I wouldnt do it either. I have heard of others doing it. Its been a long time. I only know about the brake pad thing because I once owned a EA82 that came with EA81 wagon wheels on it. They worked fine, but then I did a brake job and once I replaced the pads the wheels wouldnt move.
