January 21, 200422 yr Hey folks, I was trying to install factory curb lights into my 2004 Legacy. I assumed the wiring would be there, but it wasn't. When the door panel was off, a part fell off that I can't find a home for. It is a round wire ring, a little over an inch in diameter. Does anyone know where this goes? Also, can anyone tell me about the wiring for these lights? Thanks
January 21, 200422 yr Does your legacy have manual window cranks? sounds like the retaining ring of a window crank arm
January 21, 200422 yr Is it more like a horseshoe which curves to the outside at the ends? If so, it is as Soup says - the retainer clip for the windor crank. See if the handle pulls off.
January 21, 200422 yr Author I have power windows, so no crank. The ring is about 2 full turns of wire.
January 21, 200422 yr Hi, It's not the spring that goes on the back of the door lock barrel is it ? DaveH
