opus Posted July 27, 2009 Share Posted July 27, 2009 What do you all recommend? Quote Link to comment Share on other sites More sharing options...
Psyko Posted July 27, 2009 Share Posted July 27, 2009 How ironic. I was just wondering the same thing. Subscribed for answer... Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted July 27, 2009 Share Posted July 27, 2009 Is this on an ea81? I would recomend spraying penetrating oil around the outside of the plug and letting it set up for a while. Also find your strongest impact gun and start going to town on the thing. Few bumps forward and a few bumps back and so forth. You may have to spray and let set a few times. And as far as pennetrating oil goes... Don't go with wd-40. I would recomend pb blaster or something similar. Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted July 27, 2009 Share Posted July 27, 2009 i might suggest that after applying the pb blaster, to let the engine run to gets some heat in the block, and use a small punch/hammer and "jar" the plug nd spry more pb blaster. The heat and jarring should allow it to soak into the threads more. spray a few days on this. Quote Link to comment Share on other sites More sharing options...
4x4_Welder Posted July 27, 2009 Share Posted July 27, 2009 Are you talking about the 14mm recessed hex (allen) plug on the passenger front of the engine? That won't do you any good for a block heater, that's an access hole for pulling piston pins. It's basically open to the crankcase. If you're talking about the head drains, a socket on a ratchet usually works. Use extensions as needed. Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted July 27, 2009 Share Posted July 27, 2009 Are you talking about the 14mm recessed hex (allen) plug on the passenger front of the engine? That won't do you any good for a block heater, that's an access hole for pulling piston pins. It's basically open to the crankcase.If you're talking about the head drains, a socket on a ratchet usually works. Use extensions as needed. I have 1 car with the heater there, the EA81 rescue wagon. And I saw a car in the junkyard with the block heater same location. that is where they put it. Quote Link to comment Share on other sites More sharing options...
Psyko Posted July 27, 2009 Share Posted July 27, 2009 Are you talking about the 14mm recessed hex (allen) plug on the passenger front of the engine? That won't do you any good for a block heater, that's an access hole for pulling piston pins. It's basically open to the crankcase.If you're talking about the head drains, a socket on a ratchet usually works. Use extensions as needed. This is the EA81 I have sitting, awaiting a rebuild. Obviously only one of those is for the wrist pin (one next to crank?), so he's probably asking about the other one. Or I'm wrong and he's asking about something else entirely. (I wonder if the rest of that yellow crap will melt off when I finally fire it up...) Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted July 27, 2009 Share Posted July 27, 2009 Ya as bheinen74 stated as he suggested sounds like the way to go. Also I might add the ej block plug on the bottom of the drivers side near the water pump is the same as the block plug on the ea81 block. I know this cause nearly all the block plugs on the ea81's I have taken out end up getting destroyed slightly in the process. Quote Link to comment Share on other sites More sharing options...
opus Posted July 27, 2009 Author Share Posted July 27, 2009 Its on an ea81 and an ea82. I have 2 to do. It is the bigger of the 2 plugs on the 81. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 27, 2009 Share Posted July 27, 2009 14mm allen socket and an impact (or breaker bar if you can't get an impact on it). GD Quote Link to comment Share on other sites More sharing options...
4x4_Welder Posted July 27, 2009 Share Posted July 27, 2009 Ok, I forgot there was a water jacket plug next to it. I made a tool by welding a bolt with a 14mm head into a socket about five years ago. It has survived multiple rebuilds, it's just a bit ugly. Craftsman also has individual male hex sockets, but they get a little more expensive in that size. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 27, 2009 Share Posted July 27, 2009 Harbor Freight has a set that goes up to 17mm for like $12. I wouldn't be surprised if the smaller ones broke easily but 14mm is pretty big so I wouldn't guess that strength would be an issue. I have a set that I've impacted quite a few times with my 650 lb gun and never broke the larger sizes (12, 14, and 17). GD Quote Link to comment Share on other sites More sharing options...
zstalker Posted July 30, 2009 Share Posted July 30, 2009 http://www.sears.com/shc/s/p_10153_12605_00992612000P?vName=Tools&keyword=14mm#descriptionAnchor I got one from MAC, SnapOn would be best (this fitting is going to take some real force most likely), but Craftsman should do the trick. ~Erik~ Quote Link to comment Share on other sites More sharing options...
Gloyale Posted July 30, 2009 Share Posted July 30, 2009 Many EA82 A/C set-ups use a long-headed 14mm bolt on the front/bottom part of the bracket, securing the bracket to the block. I have cut the long 14mm head off of these bolts and then used that in combination with a 6 point 14mm socket to remove the coolant plugs and wrist pin plugs. Quote Link to comment Share on other sites More sharing options...
