Fuel starvation after replacing fuel tank
11 replies to this topic
#1 hal1971
hal1971
    New User
  • Pip
  • 6 posts
  • Quebec city, Canada
Posted 17 January 2012 - 11:16 AM
Just before christmas, I've replaced the fluel tank on my impreza 2002 TS hatchback.
The fuel tank was almost empty, after the replacement, I did 10-15 miles driving without problems. The trouble started after fueling the car full. after 1 miles of driving, the rpm was going up and down, the car was stuttering and shaking. I was able to drive home and tested the car a low speed with this problem happening more ofter.
The next morning I started the car and leave it heat for 10 minutes and when I stepped on the pedal, the car died... So I called the mechanics to have my car towed so they can check the trouble. after verifying everything ( emptying half the tank doing so). They told me it was my Gas cap that was broken and gave a generic one.
With the new gas cap and half a tank, everything was fine, car running great. I did almost 250 miles, but being not sure of the gas cap problem, I never fulled the car full, always in the half 3/4 range.
Last week I fueled the car full, guest what, starvation again...
For now i'm driving without cap and everything's fine, I have the check engine led, but car running great.
A original gas cap cost 35$ buck, the dealer needed my serial because they where 2 kind of cap that year and told me I SHOULD by an original...
My question: Can a broken gas cap do this kind of trouble ???
#2 naru
naru
    1000+ Super USER!
  • 2,296 posts
  • under the bridge
Posted 17 January 2012 - 12:13 PM
Yes,if the vacuum relief valve doesn`t work.
#3 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 17 January 2012 - 04:35 PM
Yes the tank is not getting fresh air as it uses up fuel, so you get a vacume lock. If it is really bad you can crush the fuel tank.
#4 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 17 January 2012 - 07:57 PM
who installed the tank??
any chance the hoses got mixed up, kinked, twisted??
#5 hal1971
hal1971
    New User
  • Pip
  • 6 posts
Posted 18 January 2012 - 09:27 AM
I hope they checked that, because I had to return twice, the first time they told me they did a shampoo and it was condensation, the second time, they told me it was the gas cap. Do I really have to buy a Subaru Cap or I can go OEM ?
#6 johnceggleston
johnceggleston
  • 6,712 posts
  • Virginia
Posted 18 January 2012 - 01:58 PM
i doubt it is the cap, but if you want to try oem, buy a used one.
i'd make the shop that installed the tank fix it. something is not right.
#7 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus. '03H6OBW,'06WRX
  • 7,955 posts
  • Texas
Posted 18 January 2012 - 02:33 PM
fill the tank near the shop, leave the cap loose, drive carefully to the shop, fastne cap normally and take mechanic for a ride.
make sure this will duplicate the problem.
they installed something wrong, broke something,or got a bad part.
#8 naru
naru
    1000+ Super USER!
  • 2,296 posts
  • under the bridge
Posted 18 January 2012 - 08:55 PM
Probably pinched the breather line.
Tank should not have to breathe through the gas cap.
#9 hal1971
hal1971
    New User
  • Pip
  • 6 posts
Posted 19 January 2012 - 09:35 AM
I'm very unlucky with this car, each time I go to a shop for a fix, I have to return because something is wrong. Is Subaru so hard to work on ;)
I'm in the process of buying a new sub, I will leave the old one at the shop so they can check and recheck...
#10 1 Lucky Texan
1 Lucky Texan
  • 7,955 posts
  • Texas
Posted 25 January 2012 - 04:26 PM
how did this turn out?
#11 hal1971
hal1971
    New User
  • Pip
  • 6 posts
Posted 26 January 2012 - 12:25 PM
Did not have the chance to bring it where they installed the tank and frankly i'm not sure I want them to work on it anymore. If it's the breather line, is it a costly job to have it checked ?
I'm still running with no gaz cap, everything seems to be fine.
#12 hal1971
hal1971
    New User
  • Pip
  • 6 posts
Posted 14 February 2012 - 12:25 PM
A little update,
Had to go to a subaru dealer for a recall.
Since I was there I asked them to check my tank installation, they analysed the check engine code and told me it was surely a cable piched under the new tank. a 4-5 hour job to check at 110$. So I asked them if I can continue driving without my gaz cap and they told me that it's not a problem. I'm driving like this since then and car's running fine.
