Tires Sizes (again I know) Loyale
tire 165sr13 4x140
8 replies to this topic
#1 Silas Cruse
Silas Cruse
    Advanced Member
  • PipPipPip
  • 84 posts
  • Dallas Oregon
Posted 11 February 2014 - 09:50 PM
So my thought is to use 4 spare wheels that are 15 inches, and run 165-65r15 if I can find them.
I compared sizes at:
http://www.tacomawor...80r13-165-65r15
Any thoughts ?
#2 Subaru_dude
Subaru_dude
    1000+ Super USER!
  • 1,528 posts
  • Morristown, TN
Posted 12 February 2014 - 01:00 AM
What do you mean by spare wheels? If you mean the donuts, you can't put a normal size tire on a donut because it's WAY to narrow.
#3 bratman2
bratman2
    Eat, Live, Breath Subaru
  • 620 posts
  • Aurora
Posted 12 February 2014 - 09:23 AM
I have heard they flex a lot under normal driving also. I wouldn't do it myself.
#4 robm
robm
    Subaru Nut
  • 826 posts
  • Terrace, B.C.
Posted 12 February 2014 - 11:41 AM
The diameter is really close to stock 165/80-R13.
The wheels that come with the stock spare tire do not fit normal tires.
Standard 15" wheels redrilled for 4 x 140 may be too wide for 165 tires, but it is worth finding out.  What is the recommended width for that tire?  What width are your rims?
#5 El Presidente
El Presidente
    Subaru Fanatic!
  • 611 posts
  • Northgate/Seattle, WA
Posted 12 February 2014 - 03:56 PM
Why do you want to stick with a 165mm wide tire? A 195mm or 205mm wide tire will fit fine and they are a lot easier to find used or new. You could find wheels to fit a 165mm wide tire, but it will take some looking because its not a common size at all. 195/60/15 is almost the same size as a stock tire and really common. 205/60/15's will also work, they're just a wheezybird hair bigger.
Josh
Apparently the posting system censors the word c#nt to wheezybird..huh
Edited by El Presidente, 12 February 2014 - 03:58 PM.
#6 robm
robm
    Subaru Nut
  • 826 posts
  • Terrace, B.C.
Posted 13 February 2014 - 12:05 PM
Another point I forgot the first time:  Make sure the load rating is close to the same as stock.
The 165/65-R15's might be lower than the 165/80-R13's.   I wouldn't use less than about 82T on a tire used hard, year round.  ( I go a bit less on winter tires, because all I can find are 155/80-R13's. But then I make sure i don't go fast, and try to keep the loads down, but I wouldn't want to drive like this all the time.)
I can't find any major manufacturer that makes that size.
#7 Silas Cruse
Silas Cruse
    Advanced Member
  • PipPipPip
  • 84 posts
  • Dallas Oregon
Posted 13 February 2014 - 01:51 PM
195/60/15 looks like the winner.
As for the rims, yes the 15 inch spare rims are what i am hoping will cheaply* enable me to run 15 inch tires :)
Without doing too many mods.
#8 El Presidente
El Presidente
    Subaru Fanatic!
  • 611 posts
Posted 13 February 2014 - 06:36 PM
Spare rims are too narrow for 195/60/15's and even if they fit its a really bad idea, just drop the thought of using spare rims for everyday use and get some normal 15" 6lug wheels. Convert them to 4x140mm, or your hubs to 6 lug instead. I've bought a full set of 6lug steel wheels for $40 and all you need after that is a drill bit. This stuff you don't wanna hack, I've had wheels fall off while driving and its not fun.
Josh
#9 disom93
disom93
    USMB is life!
  • 195 posts
  • Galax VA
Posted 14 February 2014 - 09:41 AM
Ive drilled 6 lugs to 4 its awesome and easy
Also tagged with one or more of these keywords: tire 165sr13, 4x140
