ej22 swap no spark on cylinders 1 and 2
Tye
cylinders 3 and 4 are sparking the car starts but only runs on those two cylinders.
cylinder 1 has a very weak spark, cylinder 2 has no spark at all,
i just put a new coil-pack in yet nothing changed
the spark plugs and wires are fairly new
any help is much appreciated
  • Like 1
first guess,
either the coil or the igniter.
both operate in a front (cyl. 1 & 2) vs. rear (cyl. 3 & 4) manner.
the coil has plug wires connected to it.
the igniter is mounted on the fire wall just left (driver side) of the trans ''dog bone'' mount .
if you end up buying parts to diagnose the problem,
i would buy used.
neither of these items fail every day so used is a safe bet.
and WAY cheaper if you buy one you do not need.
but i would check the plug wires first.
they cause more mis-fire problems than all other causes combined.
swap your wires from the front cylinders to the rear cylinders.
first guess,
i would buy used.
i just bought a brand new coil,
decided to put in new spark plugs today
looks like cylinder 1 and 2 are flooded but not 3 and 4.
the plug wires seem to all be good because i switched them around without any change.
the igniter worked fine when i took it out of the legacy.
although i have noticed it has a surging idle when starting up and after giving it gas
looks like cylinder 1 and 2 are flooded but not 3 and 4. (flooded because they are not firing.)
the plug wires seem to all be good because i switched them around without any change.(ffront to rear?.)
if this is true,
then there is no way you have a spark issue.
you must have missed something.
Edited by johnceggleston
  • Like 1
Listen to the above.  Start by double checking timing.  Also the coil packs don't like to be fired without a solid ground when testing.  Many a new coil pack has been roasted by improper grounding.  How are you testing your spark?  Screwdriver in wire is not a good idea.  You should use a proper spark tester or solid alligator clips on base of plug to block.
Cheers,
if this is true,
Cheers,
you guys are right there is spark in all cylinders but only after I unplug the alternator, also when the alternator is plugged in a fusible link in the black box next to the coolant recovery tank starts smoking. could this be a ground issue or a bad alternator?
I just replaced the alternator a few weeks ago because the old one was overcharging.
also when the alternator is plugged in and the car is running the voltage gauge is well above 18 volts
Edited by Tye
EJs are not my specialty...  Check the wiring, for sure.  Make sure you have a good clean ground between the engine and battery.  And the brackets, etc on the alternator.  Might be good to take it to one of the stores that will test it for free.
The regulator is either being tricked by a bad / wrong connection, or blown out and failed in "full on" mode.
I am assuming the battery and its connections are good, because it cranks, but check those too, if they are unknown.
  • Like 1
is this a new swap? you never got it running? Was or is your ej swap car auto? they have a neautral switch in the ej loom you have to bypass. did your ej swap car have a clutch start switch?
this is a new swap, out of a manual 92 legacy
it does run but very poorly unless the alternator is unplugged.
the alternator is brand new so i cant imagine it has already gone bad
Is the alternator brand new or is it rebuilt from auto-zone or something.  Take your alternator to your local Battery Systems.  This sounds like an incorrectly assembled alt.  Overvoltage is everbit as damaging as undervoltage.  Get this checked thoroughly before you do to much more troubleshooting.  Just Me Though.
Cheers,
The regulator in an alternator sets the output voltage to a normal charge voltage, could be around 13.8 to 14 V some maybe a few tenths more. A battery with a shorted or discharged cell will try to pull that voltage down, if it's internal resistance is low enough. The alternator will try to deliver all the current it can, but the voltage won't go over the setpoint because of that. A battery with an open cell could cause trouble for the alternator, as it may not have enough load on it to regulate properly. But in the case of the op, a battery with an open cell can't start an engine.
  • Like 1
Got the alternator and the battery is good although its still sending 18 volts to the battery. I am guessing its the wiring
Do you guys know where the 3 wires coming out of the alternator go?
I am still very inexperienced in wiring so i wouldn't be surprised if i made a mistake somewhere.
A good fully charged LA battery should read 12.6 volts at rest.  Rest means absolutely NO loads on it, and no charging for at least 12 to 24 hours.
12.4 with the engine running, and no alternator doesn't sound bad, but I have not measured the condition either.
Late model alternators are allmost all  Internally regulated so if it is overcharging it is the alternator likely at fault.
Modern alternators have a main power output connection usually bolted on and either a single or double wire plug, One wire supplies ignition power to excite the field coils to make it charge and the second wire is often a seven volt tap off the alternator windings to send the correct power supply to the instrument cluster.
Maybe the volt gauge is reading high because instead of a seven volt input from the alternator it is seeing full alternator output volts, Thirteen plus five equals the eighteen you are seeing because trhe gauge is expecting to see seven volts so at full output it is getting fed five volts more than expected
So if the alternator is running around thirteen volts which is normal after recovering from starter load then while it may be a little low it is not unusual, Add five volts which is the difference between a seven volt tap and a nominal twelve volts and that could well be the issue for the gauge reading high.
measure at the Battery what the alternator is actually putting out.
Edited by coxy
  • Like 1
at the battery it reads a 18 volts, could my wiring be mixed up or is it another alternator
in which case Napa keeps giving me bad alternators
also when the alternator is plugged in there is a noticeable whistle
