legacy603 Posted November 30, 2015 Share Posted November 30, 2015 So here we go I have a 06 Lego 2.5I I love this can the problem I'm having is yesterday I was on the road all day no problems went home and forgot something long story short got back in the car hit the road made it aout a mile and lost 95% of it's power and strarted to knock pulled over poped the hood she was smoking but would still idel at about a grand with a light knock try to move knock gets loud and there's no power got her home did a block test normal checked plugs found i need vavle cover gaskets but plug 3 was loose fixed that still in the bad and now burning oil I think ring any ideas thanks guys Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 30, 2015 Share Posted November 30, 2015 (edited) did it overheat? is the radiator full (look in the rad) could be slipped timing and hitting some valves - how long since timing belt service? how loose was this loose plug??? Edited November 30, 2015 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
legacy603 Posted December 1, 2015 Author Share Posted December 1, 2015 Didn't over heat rad is full plug was almost out and timing is did pulled the right side cove and belt looks to be in good shape Quote Link to comment Share on other sites More sharing options...
ccrinc Posted December 1, 2015 Share Posted December 1, 2015 Are we assuming you checked the oil level? Emily 1 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 1, 2015 Share Posted December 1, 2015 (edited) you must look at the crank timing - ALL the marks must be on. Timing can slip with the belt OK. Crank timing AND cam timing must be correct - you have an interference engine. is this original timing gear? The toothed idler fails frequently when old - tensioner occasionally. Bad tensioner or idler can let the timing slip AND allow belt to slap around inside covers making racket. spark plug issue is weird...... Edited December 1, 2015 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
legacy603 Posted December 1, 2015 Author Share Posted December 1, 2015 Oils full a 1k ago and yes it's factory timing gear Texan and when it runs it sounds like a bad miss fire with the knock after everything iv put in to this car in the past year I'm really ready to let her go she's straying the money pit decent Quote Link to comment Share on other sites More sharing options...
legacy603 Posted December 1, 2015 Author Share Posted December 1, 2015 Oils full a 1k ago and yes it's factory timing gear Texan and when it runs it sounds like a bad miss fire with the knock after everything iv put in to this car in the past year I'm really ready to let her go she's straying the money pit decent 1 Quote Link to comment Share on other sites More sharing options...
lmdew Posted December 1, 2015 Share Posted December 1, 2015 I got a 2003 that sounded like a bad rod knock and it was the idler gear hitting the water pump. The inner and outer race if the toothed Idler were there but no ball bearings. Worst one I've seen that was still running. 1 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 1, 2015 Share Posted December 1, 2015 (edited) yeah - that timing SYSTEM needs to be serviced at either; 105K miles OR 105 months, whichever comes first. An 06 model was probably put on the road in 05 so - that's 120 months or more? you may not know you trashed the valves untill you re-time the engine - I suppose leak-down testing would tell you. you have options - all will cost money. Minimum is DIY the timing belt stuff - $150 - $250 dollars and a weekend. next worst is that PLUS head rebuild with some valves., OR, get an engine from a wreck put in - but that engine should get the timing belt stuff serviced too. If you are gonna hire it done, find a shop to test the valves before spending other money. compression/leak down 'should' tell you if just the timing service will get it back on the road. Edited December 1, 2015 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
legacy603 Posted December 1, 2015 Author Share Posted December 1, 2015 Im sure they won't fit but I have the timing gear new from my old 97 ej25D just a thought Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 1, 2015 Share Posted December 1, 2015 (edited) fair chance they will work, or some of them - someone else will know I hope. get the covers off and confirm that is where the problem is - I'm just guessing really. Maybe some part numbers on the idlers will match up with numbers on the kit you have for your 97? Seems likely it's a timing system problem but.....? Edited December 1, 2015 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
legacy603 Posted December 1, 2015 Author Share Posted December 1, 2015 But..? Don't like the sounds of that Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 1, 2015 Share Posted December 1, 2015 (edited) But..? Don't like the sounds of that lol! Just that it's kinda educated guesswork on our part and the problem could be something we've not though of. Some folks have posted video or even audio files and some of the real gurus at this site can sometimes tell what is causing the noise - but I'm not sure you should be trying to run your car anymore until compression/leakdown test is done and timing components are confirmed in good shape. what did the end of the loose plug look like? was the electrode beat-up? Edited December 1, 2015 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
legacy603 Posted December 1, 2015 Author Share Posted December 1, 2015 Yea she's not going to run for a while but the plug looked line I checked the gap it was alright I really don't know how it happend Quote Link to comment Share on other sites More sharing options...
