woohoo! i got a "new" soob! but need help.
6 replies to this topic
#1 subawoohoo
subawoohoo
    Eat, Live, Breath Subaru
  • 277 posts
  • tucson
Posted 09 August 2004 - 12:21 AM
whats up yall? ok, well yesterday i got me a 1982 gl wagon. ea81, DR 4spd 4wd, lookin pretty good. well i started her up and it reved up pretty high. so a few blips of the throtle brought that back down, but when i drive it, the throttle sticks, but only when i drive, not in neutral. it doesnt get floored but it rises to about 4000 rpms. so i cant drive it yet. what could it be? it doesnt sound like the cable, but more like a vacume or selenoid type of problem. any ideas?
also when it settles down, it stays at about 2000 rpms.
and one more, the left front brake calliper siezes occationally. how can i fix this? take it appart and clean it? rebuild? its quite irritating as well.
and three of the doors dont open from the outside one at all. is this normal? normal problem that is. :rolleyes: i know ill just have to tinker with it but while im asking, ill through this out there as well.
thanks alot, im sure theres more though.
#2 [HTi]Johnson
[HTi]Johnson
    Head Trauma, inc.
  • 1,522 posts
  • Coburg, Or.
Posted 09 August 2004 - 12:38 AM
Vaccuum lines?
#3 myossfeece
myossfeece
    USMB is life!
  • 231 posts
  • UPinAsubaruRX, INDIANA
Posted 09 August 2004 - 12:43 AM
yeah try some vacuum lines. as for the doors check the hanlde rods by taking off the door panels. My sedan had a sticky driverside back door that didn;t like to open from the inside. I thought it was the child lock but wasn't. check your child locks but you said it don't open from the OUTside? check the handle rods out
#4 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 20,353 posts
  • Portland
Posted 09 August 2004 - 01:00 AM
Sounds like it's time for a carb rebuild.... perhaps somone turned up the idle adjustment screw because it wouldn't idle any lower.... hard to say till you get in there and tear it apart. Likely the carb has some part in it tho. Vacuum leak wouldn't cause it to idle high like that, but could be the reason it's been turned up. Could also be a stuck fast idle cam in the choke....
If it has AC, there's an AC idle up solenoid that's vacuum driven.....
#5 subawoohoo
subawoohoo
  • 277 posts
  • tucson
Posted 09 August 2004 - 01:55 AM
thanks a lot. well i dont know why but i havnt thought of the carb, ill check that out. but i beliueve that he rebuilt it already. BY THE WAY, what is the wiered contraption that has a nipple type thing on it that sits right behind the spring and throttle on the carb??? thanks GD. and as for vacume lines, there are two disconected but i cant figure out where they go! one has suction though. ill continue checking that tomorrow.
the only thing that really bugs me is the fact that the throttle sticks while driving! whats the concensus on that???
thanks, tyler j
#6 nutt7
nutt7
    certified hoser!
  • 241 posts
  • Tempe
Posted 09 August 2004 - 03:10 AM
try cleaning the spring and throttle linkage. do you feel the pedal resting lower when the throttle sticks?...knowing this will at least tell you if the issue lies in the linkage
as for your doors, my locks and power windows were stuck when I got my 86. I took apart the inner doors and used lots of wd40 and Li grease to help loosen things up. worked great, good luck :)
#7 bajavwnsoobnut
bajavwnsoobnut
    Insane Rally Freak
  • 3,789 posts
  • Milwaukie
Posted 09 August 2004 - 07:41 AM
for the doors check and see if you have play in the handles byt trying to pull up on them twist them a lil bit if they do twist they might be busted and you need to get new door handles. they happen alot on the older cars cause the handles are made of potmetal and have a tendency to break at the pivot point
