High Oil Pressure
8 replies to this topic
#1 subaru420
subaru420
    USMB Regular
  • PipPipPip
  • 81 posts
  • Seattle
Posted 12 August 2004 - 03:51 PM
When I'm driving, mostly on the freeway doing 65-70 or so, my oil pressure guage is sky high... to the red notch at 75 PSI alot. It chills out when I idle, or slow down to in city speeds. Is this normal? Safe?
#2 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 12 August 2004 - 04:24 PM
I wish I had your problem! Mine never seems to get high enough when its at full temp. Maybe we just have crapy sending units?
Might try a real pressure guage first and see if its really that high.
#3 exister99
exister99
    USMB is life!
  • 149 posts
  • Austin, Texas
Posted 09 February 2005 - 11:44 AM
I have the exact same problem in my '84 wagon. I drove it from Idaho to TX that way and it didn't blow up.
Have any of you had a catastrophic event as a result of maxed out oil pressure?
#4 86subaru
86subaru
    Elite Master of the Subaru
  • 3,097 posts
  • ohio
Posted 09 February 2005 - 11:57 AM
mine runs 75 psi with a add on gauge , i am running 10w-40 amsoil ,
#5 84gl
84gl
    Eat, Live, Breath Subaru
  • 294 posts
  • Southwest VA
Posted 09 February 2005 - 12:03 PM
my 80 1800 auto gl sedan has the same problem and its had 4 sending units put on it in the past 2 years its oil pressure at idle is 26psi and about 80psi at 3500rpm with a manual gauge so the sending unit and dash are right seeing as i didn't drive it right now its ok but when it becomes the daily driver aging it will get changed.
#6 exister99
exister99
    USMB is life!
  • 149 posts
  • Austin, Texas
Posted 09 February 2005 - 12:06 PM
What exactly are you going to change? Oil pump? Just the seals? Sending Unit?
I put a new sending unit it mine a few months ago and got the same readings. It seems if the oil pump seals were bad I would be getting low readings instead of high. Is this a valid assumption?
#7 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 09 February 2005 - 01:08 PM
Correct; and you might even develop a ticking in your hydro-lifters.
Higher pressure would indicate a restriction somewhere.
#8 RavenTBK
RavenTBK
    Professional Auto Thief
  • 661 posts
  • Apalachicola Natl Forest
Posted 09 February 2005 - 02:08 PM
Here.. check this. Its easier to copy+paste the address than to type out a reply. Whoops.. isnt that what I just did? Oh well..
http://www.ultimates...ead.php?t=26155
#9 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 09 February 2005 - 02:30 PM
all ea81s i have ever had(too many) have had 75 psi at highway speeds. its not a problem, its a good thing, its what they do. =]
