Cheap mods for RX
24 replies to this topic
#1 AEIOU
AEIOU
    USMB Regular
  • PipPipPip
  • 92 posts
  • Madison
Posted 08 October 2004 - 02:43 PM
I know this has sort of been covered before, But I would like to get some more information on some cheap mods I could do with the '87 RX That I hoping to get. Mods including performance/appearance welcome.
(cheap means <~$100)
#2 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 08 October 2004 - 03:30 PM
ok many can expect this from me :) i think
but megasquirt do it yerself programmable fuel injection roughky 150 ish when its all done
distributor less ignition system same as i run combined with the megasquirt
for the junkyard parts is an exra 35-45 from a junk yard for the extra parts
intercooling ect
anyways my useless.000000002 cents
#3 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 08 October 2004 - 03:37 PM
I got some BIG intercoolers if you wanna blow $100 :brow:
#4 subaru_styles
subaru_styles
    the 1st RX wagon!
  • 1,696 posts
  • OMGhi2U in da couve
maf adapter & cone filter-$30?
WRX intercooler-$80?
cat delete/lager exhaust from a shop-$80?
boost controller-$15-50?
#5 AEIOU
AEIOU
    USMB Regular
  • PipPipPip
  • 92 posts
  • Madison
Posted 08 October 2004 - 03:45 PM
hmmmmm that intercooler sounds nice. How hard are they to install?
#6 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 08 October 2004 - 03:56 PM
The manual boost controller is even cooler. You can up the boost from stock to about 10psi i believe. And that will give you the most noticable difference of all. The intercooler will then help with increased boost, and to compliment it's always nice to have a good exhaust.
-Brian
#7 MSSLGECKO
MSSLGECKO
    Certified Subaru Nut
  • 755 posts
  • Missoula
Posted 08 October 2004 - 03:59 PM
What all is involved with setting up an intercooler? (How do you do it?)
#8 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 08 October 2004 - 04:05 PM
remove the pipe that leads from your turbo to your intake, and put an intercooler in between. You will need custom pipe to go from the turbo to the I/C, and pipe leading from the I/C to your intake.
-Brian
#9 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 08 October 2004 - 04:52 PM
http://www.ultimates.../82DSCF0037.JPG
http://www.ultimates.../82DSCF0046.JPG
Shown in pic1
RX7 Top mount IC ~$20 on ebay
RX7 Recirculation valve - ~$5 on ebay
hoses and piping - From the RX7 and Dodgesubishi Starquest - $?
Manual Boost controller - ~$25 on ebay -~$10 DIY
Cone filter - $25 Autozone
Aluminum MAF adapter - $15.99 autozone
Various little crap to make it all work - ~$20
Theres a thread from within the past 24 hours that documents one users luch getting a cone filter and adapter off ebay for atoud $20 The filter sounds to be better quality than mine and the adapter is plastic.
Pic 2
Hood scoop- $30 on ebay (unpainted)
Only fabrication that had to be done was welding a small tube onto one of the IC pipes for the Recirc valve. Also had to drill out the end of the little pastic silencer on the MAF hose to plumb the recirc valve.
Also, effective hood scoop usage requires cutting a hole in the hood.
mine looks like this
http://usmb.net/albu.../things_008.jpg
All prices listed are estimates .. YMMV.. being the cheapskate that I am you can damn well bet I didn't pay that much :lol:
#10 MSSLGECKO
MSSLGECKO
  • 755 posts
  • Missoula
Posted 08 October 2004 - 05:00 PM
Thanks a lot.
#11 AEIOU
AEIOU
    USMB Regular
  • PipPipPip
  • 92 posts
  • Madison
Posted 08 October 2004 - 10:25 PM
How a about that mnual boost control? what is it like? How do you install it? is it engine/turbo specific? Is it better to get that or an intercooler 1st?
#12 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 08 October 2004 - 10:55 PM
Its probably better to get an IC first, but I actually did the boost controller about 2 weeks before the IC.. with the IC you can run more boost.
Boost controoler takes about 10 minutes to install.. its not car specific
One important thing that I forgot to put on the list above.. boost gauge!!
One thing I cannot stress enough. If you are going to mod you motor, get it in tip top stock condition first.
#13 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 08 October 2004 - 11:06 PM
maybe i am paranoid and depend on electronics to much
but do you really want to trust your boost to sumthing as simple and the spring in a pen? eventually it could corrod and sieze up i doubt it but... it could happen
it could jam up from contamination oil ect that subie's are known for leaking
stuff like that
they work fine and all from what i see
but eh i am paranoid on somethings :)
#14 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 08 October 2004 - 11:07 PM
Dammit clayton! Leave us cheapskates alone!!
I already told you onece today.. back in your cage :lol:
#15 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 09 October 2004 - 12:01 AM
and i told u if you think your big enough then you can try and cage me :)
now me in a cage is amusing but does not help this fellow with his questions
#16 subaru_styles
subaru_styles
    the 1st RX wagon!
  • 1,696 posts
Posted 09 October 2004 - 12:15 AM
thats only if you MBC is the ball spring type. mines not:brow:
#17 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 09 October 2004 - 12:41 AM
I'm assuming you are using a granger valve then?
Having used both, I like my ball and spring type better.. Just based on my experience :shrug:
#18 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 09 October 2004 - 01:35 AM
anybody want to build me one? (a boost contorler)
#19 subaru_styles
subaru_styles
    the 1st RX wagon!
  • 1,696 posts
Posted 09 October 2004 - 01:46 AM
you can find some el-cheapos on ebay
#20 AEIOU
AEIOU
    USMB Regular
  • PipPipPip
  • 92 posts
  • Madison
Posted 09 October 2004 - 08:30 AM
would it be better to go with a WRX intercooler or some other? I saw tons of variety on ebay.
#21 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 09 October 2004 - 08:58 AM
It all depends on how much money you want to spend.
#22 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 09 October 2004 - 11:05 AM
35-50 junk yard
saab apc setup like me yay!
#23 AEIOU
AEIOU
    USMB Regular
  • PipPipPip
  • 92 posts
  • Madison
Posted 09 October 2004 - 01:37 PM
the WRX one was ~ $20, saw others a bout for that too, about that price range would be nice.
#24 subaru_styles
subaru_styles
    the 1st RX wagon!
  • 1,696 posts
Posted 09 October 2004 - 03:23 PM
AEIOU- if your buying a used wrx IC off the net make sure it has:
both cast elbows
y-pipe
bpv
#25 AEIOU
AEIOU
    USMB Regular
  • PipPipPip
  • 92 posts
  • Madison
Posted 10 October 2004 - 07:30 PM
Yup, definately have to get the engine running better first. Doesn't idle too well, dies. Will probably need at least a tune up, altough I'm wondering if fuel system cleaner would help, because I guess it was sitting for a while, so it may just need to be cleaned out a bit. I definately like the sound of it though :brow: . Very Mean and agresive, although that might be because of a bad exaughst. I'm not sure. Its definately a car to work on.
