dave1rr Posted January 15, 2005 Share Posted January 15, 2005 Never had an electrical problem in my car before. 1996 Impreza. When I started my car after work tonight, started and ran fine but all lights would go from normal brightness to slightly dim and back approxmately every second (heater fan speed also varied at the same time). It also seemed to vary with engine speed. This continued for several minutes and brightness was back to normal. During the half hour drive home it would vary from normal to "pulsing" every few minutes. By the time I got home it was back to a continuous pulsing. Opened the hood and the alternator was making a slight squeeling sound. Voltage across the battery terminals was about 11.5 to 12.5 volts. I belive the voltage should be about 13.5 volts. Before I run out and buy an alternator, can anyone confirm that is sounds like an alternator going bad? Thanks Quote Link to comment Share on other sites More sharing options...
northguy Posted January 15, 2005 Share Posted January 15, 2005 Subaru had a recall on the alternator in my wife's 96 Legacy. You might want to check it out - they are spendy. Quote Link to comment Share on other sites More sharing options...
frag Posted January 15, 2005 Share Posted January 15, 2005 Your symptoms very much sound like a failing alternator. If so, you can get a Subaru rebuilt cheap at 1stSubaruparts. I got mine there. https://www.1stsubaruparts.com/ Good luck! Quote Link to comment Share on other sites More sharing options...
jeansain Posted January 16, 2005 Share Posted January 16, 2005 Your symptoms very much sound like a failing alternator. If so, you can get a Subaru rebuilt cheap at 1stSubaruparts. I got mine there. https://www.1stsubaruparts.com/ Good luck! Could it not be just the voltage regulator/brushes? Quote Link to comment Share on other sites More sharing options...
edrach Posted January 16, 2005 Share Posted January 16, 2005 Most likely voltage regulator but that is internal to the alternator. Worn brushes typically result in less voltage and not more which is a sign that the voltage regulator is failing. Could it not be just the voltage regulator/brushes? Quote Link to comment Share on other sites More sharing options...
dave1rr Posted January 19, 2005 Author Share Posted January 19, 2005 It turns out it was the alternator. I replaced it with a remanufactured Bosch alternator for about $175. Has anyone had any experience with the Bosch alternators? Just hope this one lasts. All the lights seem a little brighter now(headlights, panel, etc.). I remember when the car was new I turned down the panel lights a notch and over time I stopped doing that. It seems the alternator was gradually becoming less effective and I didn't notice it. The voltage with the new alternator is right around 14.5 volts at the battery which is what it should be. At first, with the brighter lights, I thought the bulbs were going to start burning out one by one . Also, thanks for the recall info. I just stopped by my dealer and was no recall for my VIN. But, then again, I don't trust them to change my oil. Dave Quote Link to comment Share on other sites More sharing options...
cookie Posted January 20, 2005 Share Posted January 20, 2005 in the past and found them to be better quality but far more expensive than the local parts house ones. I got an additional 150,000 miles on the one on my Mercedes and it was still going when I sold the car. This means it outlasted the original. Quote Link to comment Share on other sites More sharing options...
northguy Posted January 20, 2005 Share Posted January 20, 2005 You should be good to go for the life of your car. Quote Link to comment Share on other sites More sharing options...
harborseal55 Posted January 25, 2005 Share Posted January 25, 2005 An option I've found to replacing alternators has been to take them to an electrical shop that specializes in rebuilding starters and alternators, that way you can have YOUR unit rebuilt rather than getting an exchange unit. I've used a place in San Francisco called "Rite Way" for years who has been able to service anything I've brought in same day (Toyota alt, BMW motorcycle alternator, Moto Guzzi starter). With 185K, I was planning to bring my still-operating alternator to them for a "preventative" service, as often only the brushes wear out (wear too short to make contact) and they resurface the area where the brushes contact, along with checking everything else out. Typically less expensive than an exchange unit and better work. Quote Link to comment Share on other sites More sharing options...
