hotwire or flapper?
11 replies to this topic
#1 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 27 August 2003 - 12:41 AM
which mpfi system is better, hotwire, or the flapper air flow sensor? im going to turbo a na mpfi motor, and need to know what computer system would be the best. and what years they came on.
#2 Hondasucks
Hondasucks
    Subaru Technician
  • 4,760 posts
  • Vancouver, WA
Posted 27 August 2003 - 12:53 AM
All the SPFI's I have seen, are hot-wire. My 87 Turbo is VAF (Vane Air Flow, i.e., flapper), my 86 XT Non-turbo was also VAF. I dunno if the later ones were Hot-Wire or not...
#3 GLCraig
GLCraig
    Livin' the live
  • 2,706 posts
  • LV, Washington
Posted 27 August 2003 - 01:54 AM
There were hotwire turbos the first year was probably 88, these also used the crankangle distributor. You might run into trouble is you take parts form a fulltime 4wd turbo with an automatic. I'm not sure if the TCU for the 4EAT ties into the ECU, like they do with legacys.
#4 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 27 August 2003 - 08:45 AM
Thats interesting.. I have had some questions about hotwire versus vane.. my 87 is a hotwire, but I see one post above that says their 87 is a vane type, and skips 87 is also vane type.. but my 87 is hotwire.. weird
#5 XSNRG
XSNRG
    Elite Master of the Subaru
  • 3,657 posts
  • Olympia
Posted 27 August 2003 - 09:05 AM
I was under the impression that '85/'86 was the early style and '87/later the newer style? '86/'87 could depend on early/late?
#6 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 27 August 2003 - 03:04 PM
well, i just pulled an ea82 mpfi out of the junkyard today. its an 85 xt. i got the wiring, the computer, the long block, and the maf sensor. looked like a flapper to me. would this be a good one to turbo? are the older ones the same, turbo, or na? like is this computer just waiting to see boost?
#7 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 27 August 2003 - 04:29 PM
The hot wire MAF came out in 87.
Caleb mine is a hot wire.
The 85 was a vane style ie flapper door MAF
Arguments Pro Con
Hot wire
Pro -
less restriction to the flow of air
more accurate in all temps
With it you get a crank angle dist. as Craig says, which is more accurate for firing fuel and controls ig. timing.
Quicker responce to air flow changes
Con-
not "tuneable"
with it you get the ECU controled over boost fuel cut
bit more fragile than vane
Vane style
Pro -
Has a tuneable spring loaded vane, less spring tension = richer mix
Has a over boost switch which can be easily unplugged
Con -
Moving mechanical parts
Some restriction to the air flow (has to push the flapper open)
Standard distrib. with vacuum advance diaph.on side.
Hope this helps, if I missed anything or errored, please chime in
#8 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 27 August 2003 - 05:40 PM
does that go for na and turbo? thanks skip!
#9 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
Posted 27 August 2003 - 05:52 PM
yes the basics are the same but the ECU's may be different.
Sorry I have no info on the NA systems.
#10 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 27 August 2003 - 06:08 PM
im sure it will work ok... we'll see:banana:
#11 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 28 August 2003 - 06:29 PM
so is there a cfm that will max out the movement of the flapper?do i have to put a checkball on the vaccum advance hose, so i dont boost the disty?
#12 Hondasucks
Hondasucks
    Subaru Technician
  • 4,760 posts
  • Vancouver, WA
Posted 28 August 2003 - 11:54 PM
Went out and looked at my car, cuz my curiosity was up. I do not have a vac. advance on my dizzy, and my MAF LOOKS like a Hot-Wire type, but it has a plug in the side, adn if you take the plug out, there is a screw behind it that looks like an adjustment screw of some kind. Do I have some weird system??
