Changed battery, car won't idle properly
10 replies to this topic
#1 Bespoke76
Bespoke76
    New User
  • Pip
  • 1 posts
  • San Diego
Posted 19 May 2005 - 10:25 AM
Hi there,
I changed the battery on our Subaru Legacy L (2000) last week and now the car can't hold a constant rpm at traffic lights etc. The needle slowly falls to about 100 rpm before bouncing back up to around 900 rpm. My mechanic says its probably just the throttle body that needs cleaning...does that sound right?
Cheers
Bespoke76
#2 mtsmiths
mtsmiths
    Subaru Master
  • 1,662 posts
  • Kailua-Kona, Hawaii
Posted 19 May 2005 - 10:33 AM
Could be lots of things, but prolly just a coincidence and not related to the charge ... unless, you didn't hook the charger up backwards along the line did you?
#3 All_talk
All_talk
    1000+ Super USER!
  • 1,093 posts
  • Thorp (Ellensburg)
Posted 19 May 2005 - 11:02 AM
If the battery was diconnected long enough it might have reset the ECU and its having ti re-learn the idle setup... just a thought.
Gary
#4 Sweet82
Sweet82
    Elite Master of the Subaru
  • 3,274 posts
  • Salt Lake City
Posted 19 May 2005 - 11:13 AM
Charge the battery again and see it the problem goes away :lol:
My money's on two different problems. If your talking about your original battery, it's now 5 years old and probably getting to the point of needing replacement anyway.
Two things, I'd try
First a couple of bottles of carb/injector cleaner through the fuel system over the next few weeks.
Second check your antifreeze level? My trooper will idle funny, (high & low) at the intersections when the antifreeze level get low.
Good luck,
Glenn
82 SubaruHummer
01 Forester
#5 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 19 May 2005 - 12:08 PM
I agree with All Talk about the ECU. The owners manual talks about the learning procedure I think.
#6 forester2002s
forester2002s
    Subaru Fanatic!
  • 848 posts
  • Vancouver Canada
Posted 19 May 2005 - 12:27 PM
Before resetting the ECU (which involves disconnecting power), just try starting the engine and letting it idle for about a minute. Then drive off.
This might do the trick.
#7 stevetone
stevetone
    Subaru Owner Since 1995
  • PipPipPip
  • 114 posts
  • Stoughton, WI
Posted 19 May 2005 - 01:21 PM
Hi there,
Cheers
Bespoke76
Did you disturb any vacuum lines in the process of replacing the battery?
#8 mwatt
mwatt
    Subaru Fanatic!
  • 383 posts
  • Rockville
Posted 19 May 2005 - 03:37 PM
Disconnect the battery for approx 1 minute. Reconnect it. Make sure ALL accessories are off (lights, A/C, stereo, etc). Start the engine and DON'T TOUCH ANYTHING---DON'T TURN STEERING WHEEL--KEEP FOOT OFF OF BRAKE PEDAL--JUST LET IT IDLE FOR APPROX 60 SECONDS IN "P" (nuetral with stick shift) to re-learn the correct idle speed.
#9 mtsmiths
mtsmiths
    Subaru Master
  • 1,662 posts
Posted 19 May 2005 - 04:02 PM
I think the general consesus for a battery dance is a minimum of fifteen minutes (to an hour). BTW, open a window and leave the key in the ignition, that way you won't even turn on the dome light when you start it.
When you start driving, drive the way you want the car to perform, it will 'learn' your style, aggro, benign, wimpy, and respond that way henceforth.
#10 kidwired
kidwired
    USMB Regular
  • PipPipPip
  • 72 posts
  • Sonoma
Posted 19 May 2005 - 10:45 PM
Check your battery terminals and cables, clean and tight connections, inspect wireing and especially grnd terminations.
#11 Jack in Norfolk
Jack in Norfolk
    1000+ Super USER!
  • 1,099 posts
  • Marblehead, MA
Posted 20 May 2005 - 02:46 AM
This is almost certainly the result of faulty wiper blades!:grin:
