Leak behind oil pump wall help
16 replies to this topic
#1 CMohan
CMohan
    New User
  • PipPip
  • 24 posts
  • Portsmouth
Posted 05 June 2005 - 02:33 PM
Hi everyone, I currently have an oil leak in my 1996 subaru legacy 2.5 and, according to a mechanic, the leak is not coming from any seals, it is coming from behind the oil pump wall? I think "Oil Pump wall" is the wording he used. As pepboys doesn't get to deeply involved in engine work, the mechanic said I had to take it to someone who can fix the problem...he does not know exactly what is leaking, only that it is behind the oil pump wall.... also, last year I had my timing belt, cam seal and water pump replaced....
I was wondering if anyone has any idea what is leaking, how much work it will require to get in and fix it, and whether anyone would recommend me taking it to a dealer or engine shop...not sure which would be a little easier on my wallet and be able to fix the problem.....if anyone could provide some insight, I would greatly appreciate it. Thank you in advance for any help I get.....
#2 Olnick
Olnick
    Ol' Subaru Guy
  • Moderator
  • 3,064 posts
  • Honolulu HI
Posted 05 June 2005 - 03:14 PM
I'm no expert but it sounds like a classic case of the oil pump's back plate loosening. Search the board--there's been a fair amount of discussion of this.
Whoever did your timing belt last year should have checked the oil pump sealing (new o-ring and "loktiting" the screws) because--guess what--you gotta' remove the timing belt to get to it! Sorry. Good luck.
#3 CMohan
CMohan
    New User
  • PipPip
  • 24 posts
  • Portsmouth
Posted 05 June 2005 - 04:54 PM
Thanks for your help olnick, it's always appreciated.....do you or anyone know how you would fix the oil pumps back plate if it is loose and parts I should buy...new oil pump?....and does anyone else have any different opinion as to what the problem is....
I've looked through the haynes repair book as well as various posts on this site and it seems that removing the timing belt is more of a huge, time consuming pain rather than something which requires a lot of technical know-how....does anyone have any insight on how much technical know-how is required to do this and whether any special tools are required....thanks alot everyone.
#4 hklaine
hklaine
    ShadeTree Extraordinaire
  • 356 posts
  • Hunterdon County, NJ
Posted 05 June 2005 - 05:21 PM
There are three places where the oil pump could be leaking.
a. The o-ring between the low and high pressure sides
b. The sealant which attaches the pump to the block
c. The crank seal
The latter two would cause a visible leak. Since you have the Haynes manual, if you are mechanically inclined you should be OK. If disassembling this mess make certain to inspect/replace everything, though it seems like you had most everything except the oil pump done last time. Timing belts, cam seals, inspect idler pulley, acc. belts, water pump, thermostat, and of course the oil pump (o-ring, sealant, and tighten/loc-tite the screws inside)... If I am missing something someone can chime in I am sure.
-Heikki
#5 CMohan
CMohan
    New User
  • PipPip
  • 24 posts
  • Portsmouth
Posted 05 June 2005 - 05:28 PM
c. The crank seal
-Heikki
thank you HKlaine, a couple more questions...I don't mean to be a pest, I just want to do this all right......if the water pump, crank seal, and timing belt were replaced last year...would these need to be replaced again due to the oil leak...also, the mechanic who looked at my car said it wasn't the crank seal or anything...that the leak was coming from "behind the oil pump wall". I'm not sure what that means, but I am hoping I can fix this myself.....Maybe he didn't remove the oil pump and this is what that means....not sure.....any additional help would be great....thank you all
#6 hklaine
hklaine
  • 356 posts
Posted 05 June 2005 - 05:42 PM
I don't see any reason to replace the water pump. I generally replace the water pump on every other timing belt (120k miles).
I would personally replace the crank seal since you will be removing the oil pump.
If the timing belt isn't due, shouldn't be a problem to reuse it as long as it is in good condition and DOES NOT HAVE OIL ON IT from the leak.
I am not sure what the mechanic means by behind the pump wall, but would assume this means the sealant between the pump and the block. I used Permatex Ultra-Gray for this and it worked great, no leaks after 30k miles. Make sure to check the screws inside the pump. If they are loose clean the threads thoroughly and apply some loc-tite blue before replacing them. I found three loose in mine. And of course replace the small o-ring behind the pump as stated before.
-Heikki
#7 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 05 June 2005 - 05:57 PM
Just to add, here's pics from my timing belt job.
http://www.main.expe...ages/timingbelt
That should give you an idea of what needs to be removed. Also, if you have a visible leak, it's probably the sealent between the pump and block. The ultra grey silicone is the correct silicone to use.
#8 CMohan
CMohan
    New User
  • PipPip
  • 24 posts
  • Portsmouth
Posted 05 June 2005 - 06:09 PM
Thank's to both Hklaine and Legacy 777 for all of the advice you have given...after some careful deliberation I have decided to man-up and do the job myself. I figure if pepboys already removed all of the belts etc and got to the oil pump, all the necessary bolts and stuff should not be frozen and i should be able to remove them...worst case senario is I can't do it all and get the car towed to a place and I won't have to pay all the labor....:)
If anyone has any idea how long this should take for a newbie so I can plan out a time to do it...I would appreciate it....thank you all...I love this site
#9 hklaine
hklaine
  • 356 posts
Posted 05 June 2005 - 06:43 PM
Since it's all new to you, I would set aside a weekend. That should be sufficient but if you don't run into any snags there is no reason you shouldn't be able to get it done in a day. Good luck. :D
-Heikki
#10 wood
wood
    New User
  • Pip
  • 1 posts
  • lafayette
Posted 11 March 2009 - 05:51 PM
Hello - it looks like I have an oil ring problem and possible valve problem too. I can pay 500 bucks to the person who can fix it. I live in Lafayette, CO and number is 720-327-1312. THANKS !!!!!!!!!
#11 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 11 March 2009 - 07:00 PM
model, year, miles and symptoms?
#12 mountaingoatgruff
mountaingoatgruff
    Subaru Nut
  • 622 posts
  • Turlock, Ca
Posted 12 March 2009 - 09:08 PM
i thought the oil pumps on EJ's are supposed to be sealed with anaerobic sealer. i've read "debates" in other threads where folks have suggested there could be problems with dried up chunks of silicone getting into the oiling system. fel-pro has a crank seal set that comes with the crank seal, oil pump o-ring, and an oil pump gasket - i toss the gasket and use anaerobic sealer.
also, if you're going to replace cam seals get the two o-rings, not critical but a good "while you're there."
#13 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 12 March 2009 - 09:14 PM
resealinbg the oil pump with the proper sealant gets done at either 105,000 oe 120,000 miles depending upon the timing belt interval (60,000 x 2).
And i am surprised no one has said it yet..
PEPBOYS BAD!
nipper
#14 shortskoolbus
shortskoolbus
    USMB Regular
  • PipPipPip
  • 104 posts
  • Irvine
Posted 18 May 2009 - 08:46 PM
that o-ring, do you just rest it inside the little recess on the block and then put the pump over it? is there a better way to do that?
#15 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 19 May 2009 - 11:11 AM
Yeah, that's what you do.
You can try using some vasoline to hold the o-ring in place while you put on the oil pump.
#16 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 19 May 2009 - 12:46 PM
Sometimes I use just a little of that gasket adhesive stuff to hold the o-ring in the block recess so it doesn't fall out. The first time I did it, the o-ring fell out of the recess but I pulled the oil pump back off to double check something and noticed it phew!.
Posted Image
o-ring part # varies sometimes for different years
Posted ImagePosted Image
#17 shortskoolbus
shortskoolbus
    USMB Regular
  • PipPipPip
  • 104 posts
  • Irvine
Posted 19 May 2009 - 01:46 PM
hmm
i wonder if my o-ring is in there properly!
