"Charge" and "oil" light not working
9 replies to this topic
#1 Camelwagon
Camelwagon
    USMB is life!
  • 222 posts
  • Spokane
Posted 02 September 2005 - 09:57 AM
I opened up my dash yesterday and found that the "charge" and "oil" lights didnt have a bulb so i put one in and the "charge" still didnt work. Whats up with that? And the "oil" only worked when I turned my headlights on... very weird. Any ideas? Thanks.
#2 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 02 September 2005 - 09:58 AM
My suggestion? Drive on soldier! Watch the guages, not the idiot lights :D
#3 Camelwagon
Camelwagon
    USMB is life!
  • 222 posts
  • Spokane
Posted 02 September 2005 - 10:00 AM
Ya, true. Good thing i have them. :D
#4 KStretch55
KStretch55
    Subaru Fanatic!
  • 370 posts
  • Boise County
Posted 02 September 2005 - 10:34 AM
Have your alternator checked. The lights not working seems to be an indication that something is wrong with the voltage regulator or diodes.
#5 Camelwagon
Camelwagon
    USMB is life!
  • 222 posts
  • Spokane
Posted 02 September 2005 - 10:40 AM
Ya cuz my ammeter guage goes up and down when i have my blinkers on... So can the voltage regulator be replaced or just the whole alternator?
#6 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 02 September 2005 - 10:52 AM
It's built into your alternator. I don't think swaping alts is going to make those two lights work.
#7 edrach
edrach
    Charter member OFRT
  • 12,304 posts
  • Bothell, WA
Posted 02 September 2005 - 10:53 AM
For the cost of a working alternator you can get at Pull a Part, you'd be better off going that route rather than trying to replace the voltage regulator in your current alternator; besides I suspect your alternator may not be putting out from the symptoms you describe. A voltage regulator will only control voltage by limiting the upper range; it can't make up for drops in alternator output.
#8 1985GLWAGON
1985GLWAGON
    USMB Regular
  • PipPipPip
  • 101 posts
  • Frankfort
Posted 02 September 2005 - 10:54 AM
Same thing with my oil light, bulb is okay, but it just won't light up with the rest.
#9 KStretch55
KStretch55
    Subaru Fanatic!
  • 370 posts
  • Boise County
Posted 02 September 2005 - 11:41 AM
If you are skilled at soldering you can replace the regulator for about $30, same with the brushes ($1.50). But, with diodes involved and such, you pretty much need to be somewhat experienced.
There definitely is a correlation between the idiot lights not working and alternator function. I've experienced it, as have others I've read comments from. You would think that with alternator failure you'd get a "charge" light, but it's not always the case. It was explained to me by someone who seemed to know what they were talking about that it has to do with one or more of the diodes burning out and not allowing voltage to the light curcuit.
#10 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 02 September 2005 - 11:54 AM
I've heard of it affecting ALL the idiot lights... but just two of them?
