XT6 Photo Shoot and Q's!
10 replies to this topic
#1 SuBrat84
SuBrat84
    What's REALLY going on???
  • 1,520 posts
  • Tucson
Posted 11 September 2005 - 11:42 AM
Been workin on Smoke a little bit lately.. got it down to needing new rubber fuel lines.. a fuel pump relay.. and preferrably a better fuel pump than one out of an ea82. It needs some suspension work as the air system is a bit glitchy right now.
Posted Image
There it is.. up on blocks.. You can see the GT off to the right and Lurch in the back. That's Jessicas Honda Accord SW in the back.
Posted Image
A good overhead shot of the ER27. She screams.
Posted Image
Here it is Before I cleaned it...
Cleans up nice doesn't it?!!
Anyway... I'm dying to have this car on the road. Really the only question I have at this point is about the hood not closing flush... Is it possible it was in a minor front end collision and bent the hood supports? Or something weird bent the hood supports?? If anyone has any XT6 with a hood that close flush could you snap some pics of the bracket mount area inside the engine bay?? I think mine is bent.. but I don't want to try to "unbend" it if it's not bent.. ya know. :brow:
#2 NorthWet
NorthWet
    Eeyore Incarnate
  • 4,700 posts
  • Bremerton, WA
Posted 11 September 2005 - 12:03 PM
... at this point is about the hood not closing flush...
Are the rubber bumpers on each fender channel adjusted properly? (I assume that the XT-series have these.)
#3 Turbone
Turbone
    The Original Rob
  • Moderator
  • 11,935 posts
  • WA
Posted 11 September 2005 - 12:17 PM
You can try and adjust the bottom latch, loosen it and drop it down some.
#4 soobmater
soobmater
    Got Mud?
  • 1,668 posts
  • South Bend
Posted 11 September 2005 - 12:36 PM
u did a very good job cleaning the engine.nice work, its comin along. i also thought about the ruber bumpers because mine wern't adjusted correctly when i got the car.
#5 benebob
benebob
    Subaru Nut
  • 736 posts
  • Lancaster, PA
Posted 11 September 2005 - 12:44 PM
Yeah it has 'em. Round dough nut looking things.
#6 subyrally
subyrally
    Trust your Turbo-Lust
  • 2,807 posts
  • frederick, md
Posted 11 September 2005 - 02:40 PM
what you use to clean the engine?
#7 benebob
benebob
    Subaru Nut
  • 736 posts
  • Lancaster, PA
Posted 11 September 2005 - 02:43 PM
I've found that fantastik does a great job considering it is CHEAP and a good grease cutter. Not sure what he used here but for an engine bay, esp a white engine bay it works wonders.
#8 SuBrat84
SuBrat84
  • 1,520 posts
  • Tucson
Posted 11 September 2005 - 07:26 PM
Dish Soap (with bleach alternative), Carb Cleaner, Water & Compressed Air.
Dying for a steam cleaner to get the tougher grease you can't see in the pics...
#9 Turbone
Turbone
    The Original Rob
  • Moderator
  • 11,935 posts
  • WA
Posted 11 September 2005 - 11:35 PM
Whatever you do, dont use dishsoap on the exterior paint. It leaches out the oils in the paint and dulls the finish.
#10 SuBrat84
SuBrat84
  • 1,520 posts
  • Tucson
Posted 12 September 2005 - 07:02 PM
Thanks for the tip... I usually use laundry detergent on the exterior... any good suggestions??
#11 Turbone
Turbone
    The Original Rob
  • Moderator
  • 11,935 posts
  • WA
Posted 12 September 2005 - 11:35 PM
Sure, you can buy the good stuff at any parts store. Most major wax brands make it.
