Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
EA82 to EJ, anyone w/ a How-to?
#51
Posted 11 July 2006 - 11:12 AM
I didn't even think of it, but when I got everything dropped in there, I realized on EJ cars, it's attached to the tranny, and EA cars, it's attached to the engine. well, I'm using neither of these. can I get by without using one?
#52
Posted 11 July 2006 - 12:57 PM
2 words......pitch stopper.....what are you guys doing for this.
I drove for a year without one and didn't notice any additional wear on the mounts. I just added it just 'cause. I cut an EA82 shorter and mounted it to the top of the transmission.
#53
Posted 11 July 2006 - 01:08 PM
-=Suberdave=-
www.suberdave.com
#54
Posted 11 July 2006 - 06:00 PM
I grabbed a Legacy pitch stopper at the parts yard and found it to be the same length as the XT's, although the Legacy had a thicker rod.
It almost lined up with the slot on the bracket. Instead of slotting the slot a little more (it would have been close to the rear edge of the bracket and I didn't want it to be too thin), I had a 1/2" added to the length of the rod, and it fits fine.
on mine i used the stock WRX stopper. if you have an EA trans you need to find a stopper purch from an XT6 or a XT w/ spider intake. or the WRX one may fit on the EA trans.
-=Suberdave=-
www.suberdave.com
#55
Posted 11 July 2006 - 06:02 PM
#56
Posted 14 July 2006 - 04:53 PM
EJ22-EA82
Mine lined up in the stock holes in the crossmember, but they don't sit flat on the crossmember because the metal of the mount is larger than the flat area on the crossmember. I'm going to cut the mount back some to make it sit flat.
Oil pan on EJ seems to stick down further, like mabe 1.5 inches. I'm going to have to build a hefty skid plate to counter that.
#57
Posted 30 July 2006 - 09:10 PM
I cut the engine mounts to fit and it seems like it will work fine.
The oil pan is a big concern. I will be getting another one and another pickup tube to modify. I know I'm going to smash that sucker in on accident. It stickes 1/2" lower than the lowest point on the crossmember.
The fittings between the hard lines leading to the Power steering rack (EA82) match the EJ ones, you will have to bend the lines a bit, but they will thread into the flex lines leading up to the pump. This connection is down on the crossmember right by the passenger side axel.
The EJ radiator is too tall for the EA body. You'd have to chop the front off the hood to make it fit, and everything would be floppy. No good.
A custom airbox will be needed. I'm jamming the EJ one in that corner for now, but it looks bad and is loose. I tried modding the EA box to fit the EJ MAF, but then the intake hose wouldn't fit. The EA MAF also looks like a really bad restriction.
#58
Posted 30 July 2006 - 10:30 PM
i made brakets for the lower nubs to fit into...
and i had to cut bits out of the top of the core support for it to fit.
-=Suberdave=-
www.suberdave.com
#59
Posted 31 July 2006 - 09:01 PM
How low does your oil pan ride?
#60
Posted 02 August 2006 - 08:42 PM
Started first try. Right now, I'm using the ignition key to start the car, and the EJ ignition switch is turned on by a screwdriver. It runs nice, loud as hell, I only have two 1' long headers on it. The wiring is a mess, and I'll spend the next couple of days tidying it up and interfacing it with the EA dash.
I'm using the EA82 SPFI fuel pump and it seems to be working. Not sure about WOT at high load, not going to do that untill the rings have broken in.
This engine has more pickup at 1/2 throttle than the old one did at full.
#61
Posted 03 August 2006 - 06:57 PM
#62
Posted 03 August 2006 - 07:13 PM
The Ej22 (90 Legacy) exhaust rubs on the cross member on mine. What are you guys doing to fix that?
I made a small cut in the right side pipe so I could shift the cat away from the crossmember and then had to shorten the left pipe in two places.
#63
Posted 03 August 2006 - 11:29 PM
#64
Posted 04 August 2006 - 12:38 AM
my '92 legacy y-pipe fits almost perfectly, I just had to bash a little on the heat sheilding on the back of the piping right by the ports on the engine side to keep it from hitting the crossmember....but that's into an EA82
#65
Posted 04 August 2006 - 11:17 PM
Not a bad idea! Is it double walled pipe or single?
#66
Posted 08 August 2006 - 09:23 PM
#67
Posted 10 August 2006 - 07:08 PM
It's single walled.
#68
Posted 31 August 2006 - 09:16 PM
#69
Posted 31 August 2006 - 10:58 PM
Well I am not sure if this has been covered but I just took a crack at modifying my EA81 flywheel. So far so good.
I was skeptical at first.. but when I test fitted the EA flywheel, it slips right onto the crank shaft. It fits nice and snug. I actually had to use a bar to pop it off. So the crank shaft keeps it centered.
The holes on the EA flywheel are too small for the EJ flywheel bolts. I took a green grinding bit for my rotary tool and hit the holes. It's actually really easy to do. After doing about 1/2 of the holes I took it out to my EJ. Based on what I find, the diameter of the EJ Crank shaft holes is smaller then the EA81. I plan to ream the holes a bit more oval towards the center of the flywheel. Is this what other people had to do?
Anywho. Just thought I would cover this bit as people have raised concerns about the DIY flywheel mod.
BW
#70
Posted 01 September 2006 - 12:04 AM
I too will be doing the conversion in the near near future. got my adapter plate, got my EJ22 with 80,000 miles on it (out of a 94 Impreza sedan).
I got my wiring harness out of a 92 Legacy wagon MT, but I think I will use the impreza harness since its newer and the car has less miles and NO rust.
#71
Posted 01 September 2006 - 01:28 AM
I chose to have my flywheel balanced after its modification. Not all swappers have done this... my cost was $30 FYI.
My solution to the exhaust, after pounding the crap out of a few select spots and considering taking my grinder & flap disc to selected areas of the crossmember, shall be to obtain extra flanges from the parts yard and weld them to the tops of the Y-pipe's flanges. This will drop the whole Y-pipe about a centimeter, giving all the rough spots the remaining clearance they need while also allowing for some twist when the driveline torques.
#72
Posted 01 September 2006 - 03:01 AM
I have to admit, even with 88hatchmonster's reassurance, I was pretty nervous about modifying the flywheel, but it turned out great! I just used the flexplate from the EJ22 (donor car was an A/T), and kept modifying the holes until I could drop the bolts through all 8 holes. then walked over to the engine, lined it up, and bolted it in! worked like a charm!
#73
Posted 01 September 2006 - 09:26 AM
quote]
Good tip.
I think the difference is that I have an EA81 flywheel. Going to keep my EA81 tranny and go w/a centerforce clutch.
BW
#74
Posted 01 September 2006 - 11:22 PM
BW
The important part is the pressure plate. Get one for an XT6. You'll also need to get a throwout bearing for an '85 Nissan 720 pickup to run that PP with an EA81 4spd.
The stock EA81 clutch plate is more than adequate when paired with an XT6 pressure plate.
#75
Posted 02 September 2006 - 02:39 AM
I was cheap, and used my virtually new EA82 clutch kit that was in my lifted wagon....and it is not strong enough to hold everything the EJ22 can give! it's enough to get me around, but I can't use more than 1/2-3/4 throttle, and it still accellerates quite a bit faster than my legacy or any EA82 car that I've owned ever did!
also, there wasn't even a hint of vibration from the flywheel! very smooth running, even up to high-rpm.
I've got a few good diagrams, including a FSM and ECU pinout for a 92 legacy. I'd be more than happy to help in the making of a write up for this swap, much like the SPFI conversion manual
