Help needed quickly! front crank seal
21 replies to this topic
#1 Dylan86GL10
Dylan86GL10
    USMB is life!
  • 226 posts
  • Tidewater, VA
Posted 07 January 2006 - 02:13 PM
Posted ImageHello all,
I'm trying to replace the front crank seal. Is it supposed to go in flush with the block? The old one wasn't and two new ones won't either. There apprears to be a metal strip in there about 1/2 the circumference that prevents the seal from going in all the way. Is this supposed to be there?
Also is there anyway to remove the a/c condensor with loosing the freon? I've got the radiator out but still limited room.
Thanks!
#2 Dylan86GL10
Dylan86GL10
    USMB is life!
  • 226 posts
  • Tidewater, VA
Posted 07 January 2006 - 02:51 PM
On that note, would it be possible for a front main bearing to slip into the front seal area? That appears to be what happened. The front main bearing is coming out through the front of the motor and forced the front crank seal out.
Plausible?
Thanks
#3 wesley willis
wesley willis
    Eat, Live, Breath Subaru
  • 278 posts
  • port alberni, bc, canada
Posted 07 January 2006 - 03:20 PM
AFAIK there is a lip that the seal slips over to keep it from coming back out again. Maybe that's the metal strip you're talking about.
I can't really help you with that bearing issue though, not much knowledge on ea82 innards.
Do you still use your A/C? Mine quit, so I ditched the whole thing. Cleaned up the engine bay a bit.
#4 Dylan86GL10
Dylan86GL10
    USMB is life!
  • 226 posts
  • Tidewater, VA
Posted 07 January 2006 - 03:29 PM
Not sure on much of this car. Got it from someone for $150, great shape aside from the rust. Oil was everywhere under the hood and it still ran so I assumed an oil pump/seal problem. I'll either junk it or try on find another block around here.
Don't know if the A/c works, maybe just remove it altogether.
#5 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 07 January 2006 - 03:35 PM
What engine is this Ea81 or EA82? I dont recall any metal rim inside either one but I also dont think the main bearing can slip forward like that either. How far out is the seal sticking? The ones that I have replaced on EA82's go flush.
#6 Dylan86GL10
Dylan86GL10
    USMB is life!
  • 226 posts
  • Tidewater, VA
Posted 07 January 2006 - 03:43 PM
ES82T
Will Try to take a pic
thanks
#7 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 07 January 2006 - 03:55 PM
You have removed the timing belt covers, etc?
#8 Dylan86GL10
Dylan86GL10
    USMB is life!
  • 226 posts
  • Tidewater, VA
Posted 07 January 2006 - 04:11 PM
Yep everything is off the front of the motor. I've tried driving two new crank seals in but neither one in seat to the motor. In fact the old one that came out is worn down on the face from the back of the crank sprocket spinning on it. If it's possbile, it really looks like a main bearing is coming out the front of the block.
#9 wesley willis
wesley willis
  • 278 posts
Posted 07 January 2006 - 04:20 PM
uhoh. time to get a motor from RAM performance engines :drunk:
#10 89turbowagon
89turbowagon
    New User
  • PipPip
  • 13 posts
  • Battle Ground
Posted 07 January 2006 - 04:43 PM
I just replaced that seal on mine about a month ago. It goes flush. I'm not sure what would be pusing it back out, I didn't crack the block to see what's behind the seal. Sorry I can't be of more help. Did you try rotating the crank and/or the ring checking to see if that metal ring has a key on it that is keeping it from re-seating onto the crank? it might have a keyed notch that matches up with a certain position on the crank. I'm not completely sure, though, I haven't messed with that part.
#11 Dylan86GL10
Dylan86GL10
    USMB is life!
  • 226 posts
  • Tidewater, VA
Posted 07 January 2006 - 05:28 PM
Here's the car, 1986 GL10 4wd turbo ATX:
http://dodgeneon.net...ru/P1070061.JPG
http://dodgeneon.net...ru/P1070063.JPG
here's the front of the crankshaft, notice the band of metal on leftt side not present on the right:
http://dodgeneon.net...ru/P1070067.JPG
http://dodgeneon.net...ru/P1070068.JPG
http://dodgeneon.net...ru/P1070069.JPG
http://dodgeneon.net...ru/P1070070.JPG
thanks
#12 BoostedBalls
BoostedBalls
    Subaru Fanatic!
  • 446 posts
  • Sacramento, CA
Posted 07 January 2006 - 09:06 PM
Are you sure the extra metal ring isn't part of an old seal? I doubt you would have much oil pressure if the front main it walking out. Check out this diagram...I don't see any extra peice.
#13 pappy52
pappy52
    USMB Regular
  • PipPipPip
  • 111 posts
  • Camano Island, WA
Posted 07 January 2006 - 09:26 PM
Looks like part of an old seal to me. Or a seal that was installed backward, and someone tried to get it out and broke it? I looked very hard, but could not see a case split in the recess. Shouldn't a joint line be above and below crank nose?
Jon
#14 Subarian
Subarian
    1000+ Super USER!
  • 1,150 posts
  • Orem
Posted 07 January 2006 - 09:31 PM
On the A/C: there are three bolts, I think, that hold the bracket on the block. If you remove those, you can lay the compressor back on the back of the engine to give you more room.
#15 Dylan86GL10
Dylan86GL10
    USMB is life!
  • 226 posts
  • Tidewater, VA
Posted 08 January 2006 - 12:44 AM
Jon
the edges are too clean to be broken, the ends of this peice are maching flat. I'll try prying on it tomorrow.
#16 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 08 January 2006 - 01:19 AM
Make sure you have the right seal. The part # is 8067 38070.
#17 2.5GL
2.5GL
  • 269 posts
  • Sherwood, OR
Posted 08 January 2006 - 02:51 AM
looks like your bearing has spun a bit, and come out towards the front of the motor pushing your seal out and preventing your new ones from going in. Wanna try something for fun???
try to tap the bearing back in, gently, as they are brittle when struck on the side. what do you have to loose? a few minutes messing with it and slap the belt on and start 'er up, or R&R the engine?
#18 Dylan86GL10
Dylan86GL10
    USMB is life!
  • 226 posts
  • Tidewater, VA
Posted 08 January 2006 - 06:43 PM
Definately a main bearing. Need motor. Now comes the decision part out, jyard EA82, JDM EA82T, or EJ22.
Your thoughts?
#19 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 08 January 2006 - 07:57 PM
EJ22 :brow:
#20 wesley willis
wesley willis
  • 278 posts
Posted 09 January 2006 - 03:46 AM
ea82T
#21 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 09 January 2006 - 09:37 AM
ea82T
Thats what he has in it now.
#22 Dylan86GL10
Dylan86GL10
    USMB is life!
  • 226 posts
  • Tidewater, VA
Posted 09 January 2006 - 10:42 AM
Looks like I might be getting a 80k EA82 w/ T heads from GrossGary. Would like to swap in a bigger motor, But this is my first Sub, I got it for $150. Just the adapter plate would cost the cost of the car and Gary seems to have a good deal on motor (new gaskets, water pump).
Plus I got an ATX and I think that thing is marginal to start with? What is the most common failure?
