MaroonDuneDoom Posted November 11, 2003 Share Posted November 11, 2003 when my heater is set at any setting (such as defrost, floor, etc.) if i goose it, my heat will come out the defrost and then when i let her back down, it wil function as normal. is this a check valve problem? anybody? Quote Link to comment Share on other sites More sharing options...
edrach Posted November 11, 2003 Share Posted November 11, 2003 You blower controls work with engine vacuum. Check hose connections to the control portion for leaks or kinks in the tubing. Quote Link to comment Share on other sites More sharing options...
Dennis Posted November 11, 2003 Share Posted November 11, 2003 My '88 wagon (maroon, no less ) did the same thing--in fact, driving uphill would result in the dash vents blowing, and downhill the defrost vents would blow. I never bothered tearing into the dash to figure out what the problem was, though at least I made sure the vacuum hose was connected underhood. Let us know if you find anything out, I might be able to fix mine too. =) Quote Link to comment Share on other sites More sharing options...
TomRhere Posted November 11, 2003 Share Posted November 11, 2003 Thinking that maybe one of the vacuum motors(diaphrams) that move the doors, has a hole in it. Not big enough to cause that function not to work, but big enough to let the vacuum in it bleed off while under a lowered manifold vacuum caused by acceleration. Also, thinking that your car has a White vacuum canister on the Pass. side inner fender. This unit is part of the heater control plumbing. It could be bad, or going bad. Thinking it either stores vacuum, or it's a vacuum booster. Quote Link to comment Share on other sites More sharing options...
trooperjeep Posted November 11, 2003 Share Posted November 11, 2003 I'm wondering if this is related to my loss of heat problem as well. How can one tell if the vacuum is bad? I have air blowing out at the correct locations (dash, windshield, or floor) as per push button setting... but it just never gets HOT enough. T.J. Quote Link to comment Share on other sites More sharing options...
torxxx Posted November 11, 2003 Share Posted November 11, 2003 possibly clogged heater core.. have you flushed your radiator and heater core? thermostat could be another reason... does your car leak antifreeze? Quote Link to comment Share on other sites More sharing options...
trooperjeep Posted November 11, 2003 Share Posted November 11, 2003 I have flushed the heater core 3 times with a low pressure garden hose and home made adaptor. It runs clean. The thermostat was just replaced last month with a new 195'F but I was wondering if a new thermostat can be defective? It's 36'F here in NYS, but the engine never warms up beyond the 1/4 mark on the dash guage. T.J. Quote Link to comment Share on other sites More sharing options...
trooperjeep Posted November 11, 2003 Share Posted November 11, 2003 Almost forgot... no leaks of antifreeze. T.J. Quote Link to comment Share on other sites More sharing options...
calebz Posted November 11, 2003 Share Posted November 11, 2003 The thermostat was just replaced last month with a new 195'F but I was wondering if a new thermostat can be defective? Yup , it sure can.. someone else here recently had a defective new t-stat giving them some trouble... sounds like yours is stuck open maybe Quote Link to comment Share on other sites More sharing options...
torxxx Posted November 11, 2003 Share Posted November 11, 2003 go get a 180 F thermostat from Napa put it in, see if it fixes the problem and if it doesnt, bring the 180F back to napa Quote Link to comment Share on other sites More sharing options...
WagonsOnly Posted November 11, 2003 Share Posted November 11, 2003 Isn't someone on here running a 160ºF? Corky, maybe? My mom is having the same problem on her GLF, but in her case only the pass defroster is coming on. Quote Link to comment Share on other sites More sharing options...
