reseal. hg?
11 replies to this topic
#1 spokanesoob
spokanesoob
    USMB is life!
  • 239 posts
  • Spokane Wa
Posted 22 April 2008 - 02:08 PM
planning on doing a re seal and pulling the motor. so my question is should i do the head gaskets while the motor is out or dont fix whats not broken.
the motor has 166*** on it. oh and its a ea82T
#2 [HTi]Johnson
[HTi]Johnson
    Head Trauma, inc.
  • 1,522 posts
  • Coburg, Or.
Posted 22 April 2008 - 02:55 PM
When was it last resealed? Don't know? THen reseal it. Unless you're profecient at and like to pull engines. :)
#3 smithe
smithe
    USMB Regular
  • PipPipPip
  • 44 posts
  • Spokane
Posted 22 April 2008 - 03:02 PM
Can't answer the question cause I am completely ignorant on the subject but, if you are doing it in the semi near future and wouldn't mind, I would love to see what you are doing so I could learn a thing or ten. I can bring beer, cigars and offer to be a gofer for tools and bring over my sube for your laughing enjoyment if nothing else.
Erik
#4 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,013 posts
  • East Coast
Posted 22 April 2008 - 03:39 PM
are you pulling the motor for some other reason? with air tools (or even without), pulling the motor is overkill even for headgaskets unless you have a bad back.
if you're running stock turbo stuff, do them. if you're not running stock, still do them!! use Fel-Pro permatorque head gaskets and nothing else and add a few pounds to the final torque sequence. otherwise you're supposed to retorque them (annoying!)
does the motor run fine now...why are you pulling it? i'd leave it unless there's some huge reason to pull it. the cam seals, cam orings, valve cover gaskets, grommets, and oil pump and crank seals all leak like crazy on EA82's, those are very easy to replace. quick couple hour job, i'd start there unless you really need to pull the motor.
#5 misledxcracker
misledxcracker
    Guy no one ever answers
  • 846 posts
  • Bullhead City
Posted 22 April 2008 - 03:50 PM
It's a lot easier to yank out the motor and reseal it on a bench or a stand, but it's also doable in the car, just less space to work with.
I'd personally do the head gaskets too, mind as well. Cheap insurance and it saves you from having to go through the whole ordeal again.
#6 spokanesoob
spokanesoob
    USMB is life!
  • 239 posts
  • Spokane Wa
Posted 22 April 2008 - 06:38 PM
well my clutch is starting to go too. and since i will have some extra money layin around i was just gonna pull the motor replace the clutch and re seal. but i was just wonderin if i should do the HG's too. with help i have pulled a motor out of a xt in about 2 hours.
#7 smithe
smithe
    USMB Regular
  • PipPipPip
  • 44 posts
  • Spokane
Posted 22 April 2008 - 06:47 PM
I need to do my clutch as well....yeah I know, shameless dropping of the inviting myself to check out your working on yours.
#8 spokanesoob
spokanesoob
    USMB is life!
  • 239 posts
  • Spokane Wa
Posted 22 April 2008 - 06:52 PM
haha i dont have a problem with people comin to watch. but my dad might. and thats a big concern since i still live at home but maybe i will get the car port for a day or two. i plan on pullin the motor like uh around may 10th prolly :rolleyes: doubt it though.
#9 smithe
smithe
    USMB Regular
  • PipPipPip
  • 44 posts
  • Spokane
Posted 22 April 2008 - 07:10 PM
If it works out, great. If not, no worries. Being a dad myself, I totally understand.
#10 Andy FitzGibbon
Andy FitzGibbon
    Eat, Live, Breath Subaru
  • 335 posts
  • Elkins, WV
Posted 22 April 2008 - 07:26 PM
Since you're pulling the motor, and it's a turbo, I would do the head gaskets.
Andy
#11 idosubaru
idosubaru
  • 24,013 posts
  • East Coast
if the engine is nice, clean, doesn't leak and has been taken care of and never overheated....i don't know that i'd bother replacing the head gaskets. i'd be less inclined to do it on an EA82...but on an EA82T it's certainly not a bad idea.
#12 spokanesoob
spokanesoob
    USMB is life!
  • 239 posts
  • Spokane Wa
Posted 23 April 2008 - 12:24 AM
yea thats what i was thinking knowing my luck i would pull it do the clutch and re seal then a week later i would blow a HG. i think i might try and find a RX with a good body and blown HG or something. and just put my motor and trans into that one and rebuild the bad motor and just swap them out later on. now if i could find a rust free RX
