All Activity
- Past hour
I checked the troubleshooting table in the FSM for "Engine stalls after initial combustion". All the following are what it says for the fuel injector: Poor contact at terminal (could be at the injector connector itself, an issue with the wiring in the harness, poor connection at the wiring harness connectors (large black connectors near the driver side strut mount), or poor connection at the ECU. Performance characteristics unusual (maybe the mesh "birdcage" on the injector is dirty or it's sticking.) (To check if it's sticking, place the business-end of a screwdriver on the metal body of the injector and put the handle on your ear. Put voltage to the injector BRIEFLY LESS THAN A SECOND and listen for the "click-click". One click for power on, one for power off.) Clogged filter. I'd check the injector, mate. You've got a good pump, lines are clear, new filter, good regulator. Really the only other component in that fuel circuit is the injector. Maybe the mesh birdcage sieve is dirty? Either that or the injector is borked? Injector resistance should be between 0.5-2ohm (measured on the connector on the injector). If the injector tests okay and is clean on the sieve/not sticking, check the engine harness for damaged wires or poor terminal contact. (I doubt it's a contact since squeezing hose has nothing to do with electrons) :]
- Yesterday
I believe my model only has one fuel filter in the engine bay which I swapped out. I blew out the hoses with compressed air and reconnected. Didn't seem to make any difference. Out of curiosity, I pinched the outlet hose on the pressure regulator with my pressure gauge still attached (in line after the filter but before the regulator) and was able to get a reading of 40psi. With this in mind, could there be an issue with the fuel injector being stuck partially open and not allowing enough pressure to build for a correct psi reading in front of the regulator?
- Last week
Did you check that fuel filter down near the fuel pump? Too bad you had to go buy that pump but it'll give you more peace of mind in the future. Plus you can keep your old one in the car as a spare if you're ever in the situation you need it. If you do have to replace any rubber fuel hoses, Codan makes hoses that are the right diameter and are very good quality. Check out Volksbolts, they've got a good write up on fuel hoses. If you ever need some reading material.
el_freddo replied to pontoontodd's topic in Off Road
Geez, that front end took a fair hit! It’s worse than I thought it was going to be. I love how you look at the issue and go “we got this” and get stuck into it. Over here that would be a write off for a regular vehicle unless it was something special to its owner and they either know how to fix it or know someone that does and is willing to do the work. Looking forward to the detailed pics of the work done! Cheers Bennie -
Cobb accesstuner Race downloads available.
WileCyot replied to machineica's topic in Turbo Engine Tech ('91 and newer)
I could really use a copy for a 2007 STi- 16 replies
- Cobb
- Accesstuner
(and 2 more)
Tagged with:
how do you unlock a 78 Subaru?
The Beast I Drive replied to cricket's topic in Historic Subaru Forum: 50's thru 70's
If you can't get it with a slim jim, there's a kit with a hand-pump air bag, a wedge, a long rod with a hook, and some other accessories you can use. This is the kit I have and it's worked on everything I have tried it on. Use the wedge to pry the top of the window with care, then install/inflate the airbag to make enough room to manuever the hook to grip and pull the lock tab by the interior door handle, then remove the rod, airbag, and wedge, and open the door like normal. -Bill -
I tried with a slim jim but so far no luck. IWhat's the trick? It's a 78 coupe. Both doors are locked all windows are up and latched.
Thank you. Must have been someone else, I haven't had the pleasure of owning a Datsun in a couple years. I let work take over my life and slowly got rid of all the fun cars. I'm trying to get back to owning a few cars just for the fun of it instead of owning all work vehicles
Welcome. I was just in Portland and saw a beautiful Datsun pickup with a camper top etc. Was that you?
madman226 joined the community
Yeah that pump should work. Really so long as the pressure, voltage, and current draw are correct (the pump you showed looks to meet those specs) then these cars really don't care. I don't know if it'll last as long as an OEM or equivalent pump but it'll do the job. You may have to do some electrical work and figure out a mounting solution since this isn't an OEM equivalent pump but that's not a big deal and it's nothing too complicated. Sadly OEM/equivalent SPFI pumps are NLA but if you do ever want to keep a lookout for one, the part number is 42021GA242. Good luck, let us know how it goes. :]
I'd like to introduce myself, I'm Christopher. I'm an organic farmer in the Portland Oregon area. Always been a Datsun guy but starting to really enjoy the Subarus. Thanks for letting me into your group 😎
I don’t know the SPFI well at all, are you sure the fuel pressure spec is 21psi? I thought it would be more inline with other EFIs like the EJs up at about 40psi. I’ve used the same external fuel pump for a NA MPFI EA82 and an EJ22. No issues. My thinking is that your fuel pressure is half of what it should be. This could be the fuel regulator or the fuel pump itself, or both. Pull the vac line for the fuel pressure regulator and make sure it doesn’t smell of fuel. If so, it’s dead. Cheers Bennie
B straightened out the upper radiator support on the Outback. We cut out the lower radiator support. Hung a straight radiator and the condenser from upper support, hood closed, and started mocking up a new lower support. Got a piece of 3" square tubing to use for that. Put the main bumper beam back into place, squared it up, and cut a new mount for the passenger side. Will post pictures of all that later, planning on doing some fab tomorrow. The main damage to the engine seemed to be where the oil cooler/filter threads on to the block. I tapped it deeper and used one of the longer pipes we'd made when I did the same thing to the black Outback. Also like that time though the block has a hairline crack which was spraying oil everywhere. I cleaned this one out and then poured some super glue in the crack from the inside and outside. Then applied three layers of JB weld. Not real pretty but I ran the engine for a bit and I didn't see it leak a drop. So fingers crossed that will be a semi permanent fix.
For SPFI models, the fuel pressure discharge from the fuel pump is 36-50 psi. After the regulator is 20-24 psi @ 700rpm. The regulator drops the high pressure from the pump to a usable pressure for the injector. So there is a high pressure side and a low pressure side, separated by the fuel pressure regulator on the throttle body. Could be an issue with the fuel lines or filters. But most likely the fuel pump is tired and out of spec.
2.2 OBD2 swap into ‘85 Brat
Greentractorfarmer replied to Greentractorfarmer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The 560k resistor in place of the knock sensor seems to confirm the knock sensor as my problem. The on / off cut-out bucking is gone, only a significant flat spot in the low rpm range, feels like a fail-safe scenario or similar sensation. I only drove a couple of miles before parking at the shop for the mechanic to get data while driving, he has a really nice tool for that. I’m hoping he gets the time to work on this soon. Meantime, I’ve been reading a conversation on this forum where Blitz has responded to the topic “hesitation” with a solution to the nock sensor involving a variable switch to add resistance manually to the circuit. He also had removed to knock sensor . I’ve been curious if anyone has solved the knock sensor issue with a combination of a resistor in series with the knock sensor. My mechanic says that might be something to consider. Thanks for any thoughts -
Fuel pressure is not building with key to on, but not started. If he sprays a little starting fluid in, it will start and run and fuel pressure is 35psi. Fuel pressure drops to zero when the car is shut off. Both engines had this issue and it was a complete swap so the fuel pressure regulator, fuel injectors... have all been changed by the engine swap. Hard troubleshooting from 3500 miles away.
Did you measure before or after the fuel pressure regulator? If after, that seems pretty close but others more experienced would have to let you know for sure. If you decide to pull your injector, I've found a large needle nose vice grip works the best. Don't use the straight part of the jaws, rather the semi-circle part of the jaws works very well. You may have to spin the injector to loosen the 2 o-rings. Be sure not to lose the 3-padded metal ring the injector sits on top of. Throttle body & injector gasket kit I use is Walker 18015.
el_freddo started following Clutch replacement
Late to the party, if only doing clutch I drop the gearbox. On our 2000 Liberty/Legacy, I pulled the gearbox and managed to slide it back enough to work on the clutch and swap it out for a new one. This saved dropping the gearbox, I can’t remember if I managed to get away without removing the drive shafts. If I needed to it was an easy wiggle one way then the other with the gearbox because my model has diff stub axles, yours will have the male driveshafts into the gearbox to contend with. I used two steel rods that sat on the engine crossmember and the front gearbox crossmember piece. The rear crossmember and centre piece was removed, as was the gear linkages, tail shaft and exhaust. Where there’s a will there’s a way. These days I find it easier to drop the gearbox rather than lift out the engine. I put the car on ramps and go from there. If dropping the gearbox out all together I use a motorcycle jack and usually need to get the car up higher to clear the bellhousing as the engine comes out from under the car. Cheers Bennie
forthesoob joined the community
Alright folks, installed the new solenoid and still having the same issues. The CEL is now off and I'm not getting any codes from the ECU. Just checked for vacuum leaks again and it doesn't seem like there are any. Out of curiosity, I double checked my fuel pressure and am getting 19/20 psi. Is this close enough to the spec of 21 psi? And if so, would a good next step be to check the fuel injector to see if there are any issues going on there?
My 2008 Subaru Outback Sport has been involved in a wreck and likely needs to be totalled. CarFax does not show a transmission or engine replacement but I bought it having been told one was replaced. The VIN is 4S4BP61C287310455. I think I found the transmission sticker itself so the first thing is "is this the transmission tag". I have attached the sticker. I have spent many hours trying to decode and just overwhelmed. There wasa another similar sticker about two inches away with no writing left that I can see.. I am trying to prove this is a replacement from the original transmission. I am going to go back tomorrow to the salvage yard and look on the passenger side door and just trying to do everything I can to prove this. Does anyone have any advice?
