Everything posted by Subarian
Lookie what the man in the big brown van dropped off!!!
That's 'cause the cam towers aren't on them. There's not much that's prettier than clean, freshly machined metal.
Engine size 4 axle replacement
Oh, and one other thing. There's a different axle for the turbo and non-turbo cars.
I've got "Cold Gravy" in my block!
I thought you were talking about the block?I'd boil the block and replace the radiator.
Stupid Fuel Filter!!!
I actually had a clamp on both lines, but I guess one wasn't tight enough. I couldn't find my small vise grips... children find such interesting uses for tools.
question for turbo guru's, continued from last post sorta.
Not to rain on your parade, but 17 mpg for a sube isn't very good. You should be getting at least 25.
I love subes!!!
It's amazing what they'll do. I have a full-size 4wd and I'd rather drive the Subaru, especially in the snow.
rehashed carb question, but has anyone....
Stumbling or hesitation (we're talking about acceleration here) is usually caused by a bad accelerator pump. If you get a rebuild kit it should take care of it.
Look on the top front of the engine near the dipstick tube. You should find a casting that says EA 82. That means it's a 1.8 liter overhead cam engine.
New from Washington State!
Welcome. It's a great place to get information and share ideas.
turbo question
If it's before the turbo, it could. If it's after it, it shouldn't.
installing an EA82 (NA into Turbo) block.
You're on the right track. I would unbolt and disconnect only as much as you need to in order to pull the intake back out of the way.
repower/idle question ea82 SPFI
Your idle should come down almost immediately. If it doesn't, it can increase wear on transmission components (clutch in a manual, torque convertor in an auto)
I was chugging up the freeway onramp yesterday, so I decided to change my fuel filter today (carbed EA82). Every time I do this I wonder What kind of genius came up with the idea of putting a fuel filter at the lowest point in the fuel system???!!! The good news is that we're running like a top again.
I use a light coat of motor oil. When you oil head bolts, you need to be careful, because it's really easy to overtorque.
4 x 140 PCD to 4 x 114 - :( help!
It seems to me the simple solution would be to drill the new lugs centered between the old holes. There really wouldn't be any reason to weld up the old holes.
EA82 Oil Pressure
You don't need to worry about it. Your oil pressure is in the normal range for these engines. Most of your running is going to be in the 2500-3500 rpm range, anyway.
Want to buy but....
Two thoughts on blown head gaskets on older subarus: 1. Early turbo models had a nasty habit of cracking heads. Since the symptoms can be identical to a blown head gasket, it's hard to tell, but a cracked head is way more expensive. 2. If you do end up replacing a head gasket, it's not a difficult job for a fairly competent backyard mechanic. Just remember that you're working with an aluminum block and aluminum heads, and you need to treat them accordingly.
throw-out bearing? Clutch adjust?
Your clutch cable should have two nuts on the adjustment threads. The second nut is a jam nut. It's there to maintain the adjustment. If you don't have it, your clutch can't stay adjusted. It works by jamming it against the adjustment nut with a wrench while holding the adjusting nut with another wrench.
idle issues
Not sure. I'd check the PCV first.
loyale heater-defroster repair
Improper wheel alignment can also make it difficult to disengage. I had a wagon I bought for my kids to drive that hard a hard time disengaging. I got it aligned and it dropped out of 4wd perfectly. Until my son hit a curb two weeks later.
some help with an ea81 thats been sitting for a while...
20w50 sounds kind of heavy to me. I'd put in some 10w30 and see what that does for you.
replacment floormat?
I bought a really nice set at Costco that fit my 86 wagon really nicely. I think it was only like $25-30 for the whole 4 pc set.
XT drag car
I just want the flames for mine.
Milkshake any one?
Nice slime. I wish I were that good with photoshop.
Fuel pump
I only feel comfortable if I can hear my pump. I know it's not going to leave me stranded (it's happened before, that's how I know).
