Posts posted by subiemech85
now that most of the important projects are out of the way, it is time to work on the BRAT again
several months ago I bought a newer ea71 from '84 5spd fwd hatch
it has the side mount starter
I would like to mate it to the 5spd d/r from '85 wagon
what is required to mate them and install in the '79 BRAT?
clutch, transmission input shaft, driveshaft, and axle stubs compatability concerns.
all of my glass has the same markings
left, right, front
didn't check the back but assumed to be the same
NIPPON SAFETY
I vote for the manual choke
use a cable
my welder came with K-T e71t-gs self shielding welding wire, it works fine
I also bought the made in Italy 2# item# 44877 for $15 at harbor freight, and the Hobart e71t-11 for $20 at tractor supply
my lincoln pro-core 100 cost $75 at a pawn shop 3 years ago
the harbor freight blue flames helmet is good, bought a second one because the first one disappeared after welding class one day.
try miller and hobart welding boards for more help
ESAB has a lot of info.
non-turbo models...
what's wrong with the turbo models?
Not looking to spend more than I have to.
We all do Just want to be able to cruise 75 mph without flooring it on the uphills. not likely I am not looking for too much am I? yes I think my engine needs a bit of work though since my first tank of gas netted me 24-25 MPG. Is that normal? seems higher than normal 150 miles highway (65-80downhill), 70miles in town.
What to expect for mileage?
try fuelly for "average" fuel economy, mine is the gl-10
it has the ea81 with ea82 intake and carb, with the ea82T 3.7 PB 4wd
the engine makes more power than the clutch can handle, which doesn't mean much
which trans. and gearing you have will make a difference as to the "power" for going uphill or against the wind
SEARCH for subspeed
http://web.archive.org/web/20050307041648/http://www.subspeed.com/Rx.htm
http://www.ultimatesubaru.org/forum/showthread.php?t=87980&highlight=subspeed
and if $ grows on trees for you, RAM engine$
twist your nuts
If you would have SEARCHED, you woud have FOUND
http://www.ultimatesubaru.org/forum/showthread.php?t=98021&highlight=oilpan
found by searching oilpan in historic
the gauge position is not "normal"
no "overflow" tank until gen3
the bracket is for the jack
only time mine read higher is when it was 1/2 gallon low of coolant
I added a vw diesel coolant tank when I did the engine swap
refer to picture @ http://www.pixbox.se/pic_show_id30699044.html for "normal" gauge positions
this picture was taken before purchase, much cleaner now!
the '85 & '86 had different style shifter
from my '85 before I bought it
I like my "crest brown" '86 GL-10 better, roof rack, sunroof, added LSD, hitch, ea81, slightly newer radio and equalizer
you have ea82t, not ea81t, you seemed to indicate you had both in one post, IIRC
confirmed: I found an old set for a ? '79 lincoln continental town car in the shed that are not as bad as the old DUDs
clearancing of the bump stop lower pad must be done, no problem for angle grinder with cutoff wheel.
still looking for FRONT inserts!
there may be an obscure FORD
ea82 may work, CARB only
1. move to NEW gen.
2. replace BRUSHES
this is what YOU do
0. remove sparkplugs
1. remove valve covers
2. check pushtubes, are any off?
3. rotate engine and make sure valves are moving smoothly
4. rotate engine and make sure pistons are moving smoothly
5.
look under your hood
.010 IN
.014 OUT
for $1200 and a bit of patience and labor, one can come up with a nice rig
for example:
buy '85 wagon for $75, drive for a while
buy '84 BRAT for $ 100, drive for a while, transmission goes out, swap transmission and driveshaft from wagon to BRAT, in process of re-installing engine the carb is damaged, swap in intake manifold and carb from wagon
drive until scary to drive any more due to severe rusting
buy '86 GL-10 TURBOWAGON with bad engine for $100, install engine, radiator from BRAT and fuel pump from wagon
fuel tank is internally bad, cheat with 5 gallon tank in trunk area on way to buy fuel tank from j/y, have assistant help install at j/y parking lot
use the opportunity to install LSD $100
later back 1/2 of driveshaft goes bad, rear U-joint, install same from BRAT
nice wagon for about $500 by the time all is done!
lots of little incidental parts and work went into this wagon
I had vw's between the BRAT and wagon, then added a '78 BRAT and '96 SVX
there may be issues with using hydro lifter heads
TURBO heads are different
I have MSA107 good for '77 , $25 U$
digital version available
it appears to be fairly big!
from http://www.ultimatesubaru.org/forum/showthread.php?t=95356&highlight=ea82t+piston
can look at more this weekend
tires mounted, picked them up today, unloaded onto trailer, look at bill, CHARGED FOR "MOUNTING", notice tires are not balanced, take bill back to store, ask why was charged for "MOUNTING", "MOUNTING" is code for "BALANCE", wonder why not balanced, explain that I did NOT see any weights , go back home and load tires into car again to take them back to be balanced, after balancing they have weights - imagine that , take tires back and unload on trailer, admire the newly installed weights , record DOT code, 2 from Brazil, 2 from OK.
at least it's a friendly small town tire store, worked directly with the "assistant manager"
I kept the one "good" tire I took in, so now I have a spare for the spare
paid CA$H
185-70/14 winterfire 4 * $ 39
"MOUNTING" 4 * 10
valve stems 4 * 2.25
tire disposal 3 * 2.5
sales tax 14.88
total $227.38
pics later once installed
just a teaser
will most likely be installing while doing brake work
you may want ea82T pistons
IIRC = If I Recall Correctly
try a HARDWARE store or your STASH of bolts
I buy them by the # at a local farm store with extensive hardware section
Good Machine Shop In Central IA?
Posted
arnold's motor supply of ankeny
howell welding ames does good fab. work, and who knows what
