Posts posted by subiemech85
thanks for the tip it wouldn't be a true restoration WITHOUT the gasket :-\
perhaps a ea82t I am rebuilding will get the goo
last pan gasket I did on the ea81 brat engine which is in the '86 gl-10 turbowagon has not leaked in over 5 years!!
'01? HONDA rebel 250cc
'01? SUZUKI RM80 86cc
SMALL hands
AMAZING patience
HEATED garage
all-nighter with sirius-xm 60's on 6
good things WILL happen
I am fairly familiar with pulling engines, have done 5+ different cars in various ways
x-mem is 4 bolts
plan of attack is set on 4 jackstands, remove engine mount nuts from x-mem, remove 4 x-mem bolts and A-bar, then remove 12? oilpan bolts
could I also LOWER the crossmember?
YES, it is the oilpan gasket leaking
tightened the bolts, but it still leaks about 2 qt in 300 miles
is it possible to replace the oilpan gasket without pulling the engine?
TTIWWOP!!
what's the build date?
5/78 BRAT
11/79 ski wagon
start here! http://www.partsplaceinc.com/catalog/vw-air-cooled-beetle-ghia-bentley-manuals135.shtml
http://www.partsplaceinc.com are good people
and for the diesels http://www.vwdieselparts.com/
if these part numbers are bad, please help
oil seal front crankshaft 38 x 55 x 9 806738040
oil seal rear crankshaft 70 x 87 x 8.5 806770013
seal washer rocker cover 812764110
gasket oil pan 811606100 11121AA011 11121AA011
gasket oil drain 11126AA000
gasket oil pump body 824206100
oil filter cp 15208AA000
o-ring 10.8 x 2.4 806910050
o-ring 47.5 x 2.0 806947020
o-ring 15.5 x 1.5 806915050
cord cp s/plug 3 420737110
cord cp s/plug 420587110
cord cp s/plug 4 420747110
cord cp s/plug 2 420727110
cord cp distr 420777310
clip clutch fork 30539AA000
http://www.nor-as.dk/uk/OnlineCatalogue/Onlineshop/tabid/1039/Default.aspx
6705 = g2
6706 = g3
still looking for gen1 BRAT body panels :-\
YES
and TURN OFF YOUR CAPS LOCK
So thats what my SVX engine looks like. it's huge. Hopefully, this pic won't be useful to me anytime soon.
it will be come time to change the sparkplugs!
who wants to help me remove ea71?
that is SLOW!!
camera drive mode is 3 frames/sec
stop motion video slowest is 3 frames/sec
other choices are 6, 10, 15
only needed a little bit of assist to back out of the subaru swallowing hole
got home, finished washing in the rain
ttiwwop
zzz no more, just woke up
actually didn't sleep good
b called, en-route
my shopping is also done
new memory card 2gb sandisk ultra 2
camera remote control
and a propeller
I am in the beginning of a multi-year restoration
http://www.theymightberacing.com/Restoration/InSituPlanning.aspx
a/c works, fan stays
when done, I want it to look like you just stepped off the way back macnine set to 1979
don't bother, there is no torque spec
just put them on tight as possible by hand and remove with filter pliers
wv 1.6 diesel requires a torque wrench to prevent leakage
Nope
charge relay contact points
in '78 fsm there is a sketch of one for when removing headliner from coupe, remove windshield
Attn. POOPARU: I would also like a set of decals that say four wheel drive in the style of front wheel drive fender badges
So dennis did sign up, couldnt send him a pm because he refuses to empty his box.
502 messages in box
Hmmm... the last time Denis got stuck on a B road, was his prom night I believe....you are correct, SENIOR prom in the mud was funner!!
A good time should be had buy all. You in dennis.just recently registered as team subiemech85
Probally not going to be able to attend now:mad: but please the rest of you go and have fun for me. And take lots of pictures.that's what my nikon d60 does best
over 1,000 pictures on one charge, no second battery necessary
hopefully will have a new installed for the event
of my past and present.....
'84 wagon YES
'84 BRAT YES
'85 wagon YES
'89 3door RX disconnected by previous owner, never bothered to hook it up
11/79 SKI wagon N/A
5/78 BRAT N/A
'86 TURBOWAGON yes, but severely out of adjustment as if cable is too long due to ea81 engine swap but will be fixed to work correctly when turbo engine is in
6/92 loyale... it's a crap-o-matic
Brat Bed Panels
Posted
for easier access remove the taillights
gen1 has full length panels
removed the left one to clean out "bird nest" from around gas pipe and gravel from wheel well
thought about stashing "air conditioning"
lifted from http://p201.ezboard.com/quotWho-Here-Smokes-the-Green-sTuffquot-part-2/ffoxheadnetworkfrm13.showMessage?topicID=5.topic
good times
