Posts posted by subiemech85
it's more of an all over more solid, doors, suspension, tailgate, hood rod.....
only one "bad" R-word hole has presented it's uglyness
newly acquired BRAT from McBrat http://www.ultimatesubaru.org/forum/showthread.php?t=94177
this is going to be a preservation / restoration / period upgrades
many ?'s and parts request
looking for: topper, hitch, tan horn pad - willing to trade gray, rear ash tray - black - for parking brake cover, trip meter reset button
is there a way to turn OFF the center vents so they do not blow cold ambient air in the chilly winter? while still using them for "hot" air?
how do the rear seats mount?
round air cleaner box... is yours equipped with NISSAN flap motor and plastic air temp sensor controller?
what is the metal box that looks like a relay under the driver seat for?
is there an upgrade for the headlights, perhaps using h3 or similar bulbs?
speedometer seems to be reading 10+ faster than actual with 165/13"
what are you using for 13"?
how to repair the cracked dash?
is there supposed to be a strap for the glovebox door?
reproduction carpet and vinyl for floor??
wild idea: spfi intake boot for cone filter??
carb top is round
TURNING steeringwheel to full lock left, seems to want to suck itself in when almost all the way, is this normal? sure is convenient in parking lots and gas station
how accurate is the fuel meter?
seems more solid and rouger ride than gen 2 brat
where does the A bar mount????
more pics will be added once I buy a NIKON D60
here's the formula:
ea81 or ea82 engine, your choice
4wd d/r 4 or 5 spd, your choice, 5spd is less problematic - and better power ranges, just use matching driveshaft due to length differences - or go custom driveshaft with the 5spd d/r to avoid the hanger bearing
ea81 or ea82 or xt6 flywheel
ea82 or xt6 clutch kit
datsun 510 or subaru LSD, try to steal one back from "the dark side"
avoid the Vlsd for your intended purpose
requesting more pics of brat and topper, confirm build date and serial number!!!!!
does it say A69L??
got pics?
of lights, gauges, body?
where's the subspeed strut bar and filter adapter, and when are you sending them my way?????????
UPDATE!!
I read every post
reseal airbox
search
freeze
burn seat
insulated heater hose
move to where it is warmer :-p
thought I posted it over here, but ended up in newer gen :-\
? 155/sr13 + '74 SPORT MAG + gen 1 BRAT = ?
155/80/13 Primewell PS850 $30 @ farm store
unless there is something better
This guy taught me every thing I know about "master cylinder" Love Stuart Culpepper aka stan
looking to upgrade the master cylinder on '78 BRAT
LISTED as 3/4" BORE Line Thread Size:M10-1.0
also looking for rebuild kit
what's available?
gen 2?
the question is WHY DO YOU CARE????
they run fine without the STUPID USELESS COMPUTER!!!!!
I used to DISCONNECT while DRIVING just to PROVE this point!!!!!
can someone clue me it as to what happened?
shaft bushing play
ignition module
sometimes they just go bad
water choked air filter
bad dist.
BTDT on both accounts!
looking for body and suspension parts books for gen 1, 2, 3
have only found ea71/ea81 engine parts book
send them to me!
I had a set on the RX with grey and red stripes
looks like it was built WITHOUT the cable!
loyale spfi 4wd 5spd built 8/91
is there supposed to be a speedometer cable??
there is only a rubber plug!
speedomerer does NOT work
searched and nothing answered this ?
will the BRAT be gen 1??
Im considering this for saving space in the engine bay.
Subiemech, these trouble codes out of which book?
Im sorry if it insults you that i dont think you recalled those numbers from memory:lol: thanks for the numbers
how will this save space?
'85 xt service manual Publication No. G131BEA http://www.ultimatesubaru.org/forum/showthread.php?p=789677&highlight=g131%2A#post789677
where else would the lenghty description come from??
attempts to solve the problems of the EA82T beyond 175 HP were abandoned. GD
so, how did they solve the porblems up to 175 hp?
trouble code 34 aspirated air thermosensor
resistance between 00 and 0
voltage between approx 4 and 0
trouble code 21 air flow meter
measure voltage between (us) (YR) (+) and ground (BR) (-)
trouble code 14 air flow meter
measure voltage between (ufix) (LY) (+) and ground (BR) (-)
approx 5v
is approx 1v when airflow meter flap is fully closed
is approx 5v when airflow meter flap is fully open
measure resistance between (us) (YR) (+) and ground (BR) (-)
is approx 50 when airflow meter flap is fully closed
measure voltage between (ub) (G) (+) and ground (BR) (-)
approx 8v
measure resistance between (ub) (G) (+) and ground (BR) (-) approx 300
measure resistance between (ufix) (ly) (+) and ground (BR) (-) approx 200
measure resistance between (us) (YR) (+) and ground (BR) (-) approx 50 to 500 from close to open
adjusting spring tension should not make much difference when off boost!!
newly acquired BRAT from McBrat many ?'s and parts request
in Historic Subaru Forum: 50's thru 70's
Posted · Edited by subiemech85
forgot a line
ok
that explains it
how is it supposed to work?
bolt in?
small thread
