Everything posted by Ned P Pritchard
Valve springs retainers locks and pedestal washers needed
For a ea 82 carbed single port .
trans fluid rear dif. fluid engine oil filter air filter basic service inspection found steering rack boot Torn replaced. now I need to replace axle ! cut in outer boot.
86 GL wagon fuel tank replacement
well i replaced tank with a brand new one made by spectra premium out of Canada looks great fit perfectly and works outstanding so far . oh yes i found a peace of silicone rubber wrapped around the old fuel tank pick up screen in bottom of tank that was causing a fuel starvation problem and headaches six months of hell. finally she runs great again and revs out no more stalling .bs.
- Front struts
KYB gr 2 replacement struts are- Fuel tank replacement
- Car runs and stalls out ,
car starts runs well until you try l stall out .starved for fuel wait and restarts repeat same?- Car runs and stalls out ,
pictures of tank sending unit access point?- Car runs and stalls out ,
need to get more fuel from tank is full just a trickle from tube,- Car runs and stalls out ,
where is sending unit access point where does fuel line enter tank hard to tell just a look at it,NP- Car runs and stalls out ,
fuel filter is clean seems fuel line from tank is resricted only a trickle from tank ran a piece of wire thru and only a trickle coming out of pipe almost full tank what to take tank out and clean or replace need help please what is best option ,- Car runs and stalls out ,
Okay then what and where to get guage and- Car runs and stalls out ,
86,,GL carbed stalls out ,fueling problems ,fuel pump or clogged up fuel tank stalls out, oh yeah it's a 4/4 wheel wagon any easier way to clean out fuel tank, than removing ,looks like a pain in the rear PLEASE HELP ,- engine build ea 82 carbed
- cam case O rings
where to find our good quality suitable replacements the small reinforced one for oil feed to cams- Anyone interested in EA-82 Parts?
yes I can use a good ea- 82 crankshaft for a rebuild and a right hand front fender and that top carrier looks like I can use call 213-331-3141 my name is Ned Pritchard thanks a lot cool .- EA Series Bumpers
any rear bumpers with tow hitches for a 86 4/4 GL wagon low cost please?- trailer hitch needed
thanks alot any others please.- trailer hitch needed
Hitch for 86 GL 4/4 wagon . please leave information to contact .- trailer hitch needed
Hitch for 86 GL 4/4 wagon . please leave information to contact .- clutch EA 81 clutch same as EA 82?
Will IT fit the same dimension 225 mm.- 86 GL Wagon Hatch Glass
any in so cal ?- 86 GL Wagon Hatch Glass
Any Ideas where or how to replace ? may be easier to replace the whole back hatch any Ideas apreciated.- Manual choke conversion for Hitachi carb?
Will this be legal in california ? will it pass smog inspections ? my choke is broken . I need to replace with a new or other system where can i get this piece ? IE / choke cover and spring coil. - Front struts
