Everything posted by theDirtyRue
Who wants a Centerforce clutch for an EA82?
Chef Tim, How much is a LUK clutch, and how long has it lasted? Thanks
EA81 suspension is DONE finally (minus paint):D
Sounds cool, do you have some pics? Did you say that you are going to drop in an ea81TT (is that twin turbo, or something esle?) thanks,
what is it?
I'm with sandman!
Removable front fog/driving light bar. Installed. pictures (DUW)
That looks very good! Is it just a piece of square tubing w/ the bumpstops you put on? Looks simple enough, i might have a project...if i can ever afford it! Have you taken them out yet? Let us know how well it holds up to the roads! Nice work,
How much is a Dual Range Worth?
Thanks Calebz, I've been proven wrong yet again! O well, I swear that i learn 8-10 new things a day here! Now I'll I've got to do is commit it all to memory. thanks again!
Help With My New Subaru
Without knowing much about it, there are a lot of cheap mods, and a lot of more expensive mods. You can do a lot to it, but its never going to be a 12 second car unless you want to spend some serious money. get us some more details,
Tranny problems?
Alrighty, I'll try the hill thing tommorow. I don't have a hoist, but i might have axcess to one. This will most likely be a weekend project then, b/c none of my friends have done the clutch swap. O well, a learnig experience for all of us. Thanks again,
GL-10's did come with single range 5 spds, but not D/R. I'm not sure if they came with the 3AT, don't think so, but I could be wrong...
Tranny problems?
Alright, So you guys are all positive that it is the clutch? I don't mean to doubt or second guess you guys at all, but I just don't have the money to be spending it on the clutch and have that not be the problem. Is there any test or something that I can do? If it is the clutch, what's easier, pull the engine or drop the tranny? If i drop the tranny maybe i could swap it out for the D/R...? Thanks GD, I'll try and get my dad to let me drive the pick up for a bit. Thanks again,
As corky just said, come up here to Spokane. At the local Pull N' Save yard, all trannies are only $50. They usually have 10-15 subarus in the yard. I know that there is an 88 sedan that has the D/R 5 sp. in it, i just pulled the valance off of it today along withe the drivers side turn signal assembly. $385 is an absolute rip off for just a tranny. You Don't need to find an 87 gl-10 w/ an D/R 5spd to swap into your car. B/c you already have the turbo, any D/R 5spd will go in. I don't know if they even made gl-10's w/ D/R 5spds? I've thought about doing this conversion, but from what other board members are telling me, my clutch is about to go, so thats first. Anyway, Good luck,
Tranny problems?
How hard is a clutch swap? Is it something I can do by myself in an afternoon? How much should I expect to pay for it all? Thanks again,
Tranny problems?
Yes, it is a manual. How would I loosen the cable? If I loosen it and it doesn't help, does that rule out the clutch? Thanks again,
Tranny problems?
Okay, When I'm driving down the road, sometimes it seems like I'm not getting all the power to the wheels. I can't really punch it anymore. The RPM's just go up and I slowly start moving. I have a bad CV in the passenger front. Could this be the culprit, or is it something bigger, worse... the Tranny? Anyone know what my problem is and how I can fix it? Thanks,
air intake methods... EA82T
suberdave, Is that just pvc from a hardware store or sometyhing? Thanks,
Is there a way to change gearing?I'm turning 4,000rpms @ 80mph...
105 in fourth? I don't think thats true for a second.
Attempt Job Myself?
Get your advice here. You should do this yourself, especially since it's not your daily driver. Remember, if you run into any problems, you can always come here and ask! Good luck,
AC problem...fix it or ditch it?
Fans really only do you good at low speeds. Cruising you should have enough airflow going through to cool it.
Follow up with over-heating question I posted before
How hard is it to replace the O-rings?
wish me luck!
Hey Andy, I need to replace my Passenger side cv joint. Was wondering if you'd be up to it. Let me know,
The Maiden Voyage: SS Subaru
Truly amazing! Good luck with the washing and I hope you don't run into too many problems down the line from all that salt! Keep washing!
New Subaru-only Magazine?
I think that this is a great idea. In this forum, your going to get a lot of people who will want to see the older cars in your mag, mostly b/c thats what we all have. If you take this to the new generation forum, you'll see a stronger tie to the newer models obviously. They'll probably want a similar thing though, in the how-to write ups and tech pages... but they will want it for their cars, simple huamn nature. I know that if this thing does come out, it will most likely be for the newer models, but with maybe one or two stories abotu older subes. I'd still subscribe, and I'm most positive that if you advertise it right, this will be a big hit. Subarus have a bigger folllowing than most people think. Good luck and I hope to see it in newsstands soon!
EA82 Engine swap... what to replace it with?
If you can find an ea82T, it will bolt up to your tranny. It will obviously give you more power. I've never had an NA ea82, but I'm pretty sure that the Alternator and the AC unit will bolt up to it no problem. Subaru used A LOT of the same parts for their cars, and I think that alternators and AC's were some of them. Someone on here can confirm that for you. I know what it's like. I got my First subaru at 16, and I'm only 18 now. This is a GREAT place to learn about them. Good luck,
Lookie what I found abandoned at a local gas station..
If the oil pump isn't working then you should hear the lifters ticking. If it really is the oil pump, then you would need a new one or at least a new mickey mouse gasket. To get to the pump, you have to take off the timing belts, so you could check them to see if they need replacing, and if they look even remotely used, replace them, you're already there, no use in having them break later and having to do all that work over again. Good luck!
To tide you over, an awesome photo from "Catch This Fox"
I don't know if this has already been asked, butwhat program are you using to edit the video? Are you using a mac or a PC? one more question, how long until you finish? thanks,
where to buy parts online?
Check out importedcarparts.com I bought my oil pump through them for about $70, a boot for the cv, and a couple of other misc. parts. So far, everything has been working great. Their prices are cheap, and the parts are good. Give em a shot for whatever.
