Everything posted by HATCHY
Still no spark. Please help !!!
ignition fuse??
Show off your roos Mileage!
87 Hatch.. 203,764 miles. Three Engines, Second transmission,
U Pull It around Bellingham
Prices doubled
Charging issue???
Yeah Im going to buy a nissan maxima alternator for sure.
who has the lifted grey brat
I was just wondering who had the lifted grey brat. at BMC lumber in Everett, and The camo wagon?? Nice rig
Charging issue???
I checked grounds all tight.. new terminals, .Still doing it. I dont have a voltmeter which sucks. But Ill try that next. Its doing it less now for some reason, on the way homoe the light came on like 5 times. But on the way to work it went on liek 50 times.. So wierd
Charging issue???
87 hatch ea81, When Im driving at low speeds, my battery light is very dim, and will get brighter, and my lights will dim as well, and then get brighter when i step on the gas, and the battery light will go off when accel, or just reving up. I changed my belt, because the old one was a little loose and old. What do you think it could be? Alternator? or battery?
one more time please weber carb for 87 brat
When I ordered my weber kit from redline. I recieved a really crappy adapter. It did not line up well, the holes where fine but the inside was crappy and didnt line up
Some pics of my new project
My favorite model of older subaru, wow she is clean.. Very nice car man
Just put a 4speed back together. Concerned.
Congratulations though man. That's sick you fixed It
Thankfully I live 20 minutes from both pull a part junkyards. LOL. I could never rebuild a tranny or even take It apart. I do all my work in the Weather in the mud on the ground
what causes this. .
Fuseables all intact. Not burnt no sign. Usually there burnt out in the center right
what causes this. .
I need to get a volt meter. I have standard. All I have For guages is speedo. Temp and gas. No oil pressure or volts. Kind.Damn sucks. My gremlins moved over to my buddy's brat. Now he is having the exact same issue I am. These Subaru gremlins are mean. .. dirty bastards. I'll check my links. Thanks boys
what causes this. .
87 hatch standard.ea81. Good alternator donor. Guaranteed good.it is a different model though. But went right on. Was working.g perfect on friends hatch. Yeah that's what I thought it should stay running
what causes this. .
The battery wasn't really new. It was just a donor battery. And she was half dead. But we had her hooked up on the cables for at least 10 minutes. So it should have had enough juice to at least stay running. Well see How it works today with a full charge. .
what causes this. .
I put in a new battery And alternator. my battery light stays on. And the won't let any charge take place. Fire up no problem. As soon as the jumper cables come off. Car dies. I'm no electrical worker. But I'm fearing I have a bad electrical somewhere. Checked all grounds. Nothing I can see is bad. .. where to go next. Any suggestions. Ever had this issue before..
what causes this. .
Its something.g in the charging system. Battery light stays on as sports. As I take the jumper cables off it dies. What the hell... something in the charging system?? Put on new alty and a diffrwnt battery still happens. So weird. I don't want to sell it. Just frustrated speech. Habaaha
what causes this. .
Oh I know I feel ya. Its also hard Not having a shop to work in or at least a covered spot. Backyard mechanics setup. With a mudfloor. Drop a nut and its gone. . Its a great car. I wont argue with that. Slow and ugly but fun.
what causes this. .
Well three days ago it was fine so something happened within the three days. And trust me I take time fixing stuff. It just seems to be one tho g after a.other all of a sudden I've owned this hatch For 6 years and never ever had a problem with it until this month all hell is breaking g loose. And I do the routine maitnance needed. Im Not blaming anybody at all or anything. Just getting.g hard to keep dumping hundred dollar bills in a car worth 600 bucks
what causes this. .
Hahaa. I put in over 700 bucks this month and it still is messing up. Not counting the 800 on engine 400 on Weber. and the new 4sp dual range transmission. And the new set of empis arriving.g next week. . Getting old. . That's all. Gremlins are messing.g with my car
what causes this. .
It only looked hot at the connection point. And that wore goes back into the harness somewhere. Getting.g so mad at this car. About ready to sell it. Ill check it out. This sucks
what causes this. .
I was driving this morning to work. everything has been fine with the car. Then all of a sudden. My lights started dimming to almost nothing. . So then it shut off. Battery is dead. I looked at my grounds there all good clean and tight. So what's next alternator. Upon inspection of alternator I noticed that the little rubber piece that goes over to protect the screw. Has been melted and the wires looked like it had gotten hot. Not the plastic plug but theother one in the back. . Is the symptoms of a bad alternator??. Car isvroken down on the side of the road. In brier. Please help. . 87 hatch ea81
strange thing happened to me
LOL. I have nail holding my drivesa axle in. Worksfinea
Can't get the darn thing to start
Are you ge4tting fuel to the front or rear fuel filter?
Mounting fuel pumps in the rust belt
I had the same problem when I changed my pump that bracket its on broke off lucky I was able to get it back on., with screws,
