Everything posted by Goatboy
proper timing of an EA82 carbed
Thank You
What is the proper timing of an EA82 carbed??
EMERGENCY!! Timing Woes
Number one cylinder is the nearest the front of the car on the passenger side??
I was doing the timing on my EA82 and the dist. was turned as far as it could go but the timing was still off. So I pulled the dist. to turn it a tooth and it slipped and now the car won't start. How do I get it back in line?????
Water running/Gurgeling sound from under dash!!
That makes sense. It sure is an interesting sound!!
Is it normal to hear water, or whatever it is, running through the heater core? I hear it gurgeling when I am at idle. I assume it is doing it all the time but I just can't hear it over the engine and air noise. But is this normal? Do any of you experience this as well? --GoatBoy
87 wagon idles but stalls under load
I just pulled a carb off an 87 wagon at the JY the other day.
dash light dead
I'm assuming you checked your fuses, right?
Ignition timing EA82. Distributor can't turn anymore
I just bought the car last weekend and am in the process of trying to get it in the best order possible before taking it through Emissions Tests. The carb was all screwed up and the vac lines were all going to the wrong places. Still haveing idleing problems. When I was looking at the dist. I noticed the thing was spun to its max. I figure that can't be right and started asking around. I haven't put a timing light on it yet. You check the timing through that slot on the bell right? And I believe this is supposed to be 20 degrees before, right?
SWEET! I would have never thought off that. Well at least not for awhile.
Thank You much. That heads me in the right direction anyway!! This site ROCKS!!
Do you just unbolt the two hold down bolts to remove it? Then lift and turn???
Has anybody ever seen this before? Any fixes?? I'm gonna have to pull the distributor aren't I ???
Thats a possibility. I have never pulled a dist. out before. Maybe someone else did though and didn't put it back right. It is almost at 300k miles on this thing. I am sure someone has messed with this car a bunch. There were parts missing and vac lines mis routed.
The distributor is turned to its maximum clockwise. It can't go anymore. What do I do???
Carb Rebuild Questions
EA82 2bbl Hitachi. I am mechanical, I do all my own auto work but I have never done a carb rebuild. How hard is it and how long does it take?
Broken carb mounting stud
Thanks everyone! I think a new manifold and perhaps a carb rebuild while the thing is appart might be the ticket!!
Mystery vacuum line???
Sounds like that might be it. I plugged into the selenoid by the strut tower, there was nipple there that had no hose, and now it does the opposite. It races the engine when I turn on the defroster. But not everytime!!! Grrrr
Defroster is affecting idle speed
Thanks guys. I am new to Subarus. Can you tell?? I have had almost every amke of car now. I played with the vac hose and found the place I think it should be connected but now the idle will jump like 1500 RPM when I turn on the Defrost. And it doesn't do it all the time. I think I have a bad something or other!!
How can I fix a broken carb mounting stud??? Got a vac leak right on that corner now!!
When I turn on the defroster, defroster only - not heater or AC, the idle drops a few hundred RPM?? Vacuum leak I assuming but I don't know where to start??
I have a 85 GL Wagon 4x4 with a carb. There is a vacuum line not attached to anything and I am not sure where it goes. It starts on the back of a vacuum diaphram that kicks up the idle by moving the throttle. Where does the other end of the line go???
