Everything posted by msmithmmx
Over heating Fans Not Blowing
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, I opened up the fuse relay box under the hood and located the AC Main Fan Relay 1. There are 4 wires. R/Blue Y/G W/Blue and White. I tried to locate them in the ECU bundle of wires with no luck.
Looking at Used 98 Forester 195k miles ! !
msmithmmx replied to SVX_commuter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOhhhh,,, your looking at a dealer who has this car. The question is what did the dealer pay. I would think around 1,200. With that said i am lowering my price to 2,200 and thats with a 7 day / 500 mile warrenty. Watch out for that busted HG
msmithmmx replied to SVX_commuter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst here on USMB we do not pay KBB and i am sure thats what they want or around that price. Any car with almost 200K could have any problem at any time. At most I would pay 3K
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCorrect. There are soooo many wires
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere is my deal now. The pins from the diagram are not lining up with the colors noted by your entry and other entrys in the service manual. hmmmm what to do. I looked everywhere for numbers, nothing
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, which connecter. I took a pick. The factory manual says its a blue connector. Is the ECU connector or that one in the upper right.
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk, so do I strip the wire going into the ECU and touch it to the frame. Or can I pull it from the plastic connector?
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere are these pins?
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1) I replaced every relay in the engine compartment fuse box from my work subaru, the fans will still not come on. 2) Checked all the fuses 3) to make sur ethe box was gettig power I pulled the fuse for the hazards while they were on and they went off. 4) I jumpered the fans straight to the battery, they work Why won't my fans come on......
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen I turn on the AC the fans do not come on. The AC is not working as well just warm air and I do not see the AC clutch turn on. Sounds like a relay. Not sure how to jumper though
Just picked up a 97 OBW w/ 180K the issue was overheating. Before I confirm the HG issue I did a visual and noticed the fans on the radiator are not spinning at all even at temp. What test can I do to see if they come on manually. Thanks
Removing rear rotors 2000 Outback????
msmithmmx replied to jk4138's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, Yes, Yes. I broke a bolt when removing the front caliper, bolt was 3 bucks AND then I had to buy the mounting bracket 100.00 since the bolt was rust welded in. Cost we me a week without the sub. USE PB Blaster you can get it at Walmart. I wish I knew back then
msmithmmx replied to jk4138's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need to loosen the parking brake and remove the caliper. I have a 3 pound ruber malet that works wonders after 5 full blows or so
BAM! and our 95 is a goner
msmithmmx replied to Suzam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am glad everyone is OK. Now I am going to ask, how much for the 2.2? Should could live on.....
value needed 97 outback bad HG every else good...
msmithmmx replied to biglittledog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou really want that car. Sometimes you have to let her go. To bad you don't leave in PA, there are a several listed at any one time on Ebay.
AC Blows Warm when I am at a Light
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere is the deal, I put her in park on the driveway with the AC on. I opened the hood and here is what I saw. The 2 front fans on along with the AC compressor. What I did notice was this, my altanator belt is spinning just fine. My AC compressor belt is bouncing and jumping around. This may be my problem.......
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am checking tonight
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI put the belts on tight, no method to that madness. The AC system was open for a week before I swapped it out and completed the job. I just filled her up I did not do a evac.
A timeless question. Since I swapped out my AC compressor it will not blow cold air when I am just idling. When I am cruising down the highway its the artic blast. I filled it myself with the stuff off the shelf at Walmart. What is my problem?
98 OUTBACK help please
msmithmmx replied to robb1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA dealer is going to want at least 5K ( ebay 3K). I would not purchase a Subaru with the 2.5 from a used car dealer that had over 130K. UNLESS some conditions are made. You want a 7 day 1000 mile warenty for any head gasket issues (overheating). Someone just got burned about a month ago on here.
Torque Bind
msmithmmx replied to 82glsw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI purchased the additive from a dodge dealship. But I never used it, I had my tires rotated and balanced to fix the issue (Thanks Nipper)
Do I fix the HG or swap the engine
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe car with the 2.5 blown HG has 200K. It was not over heated for long. I can get a 2.2 150K for under 400.00. I figure I can sell the 2.5 motor with busted HG for 300.00. Hmmmmmmmmmmmm
Question.... What is the difficulty level for doing the HG myself on a 2.5. I have done the swap (2.5 to 2.2) and that was not that bad. I need an idea of money and time for changing out the HG. Do I need to pull the engine to do the HG (does thet make it easier). What would you do.................
msmithmmx replied to biglittledog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf its test positive for HC's its a head gasket. No if's and's or but's. Trust us, the ONLY way she will get her asking price is if she drops the head gasket problem from the description. Otherwise its just scrap metal sitting on her drive way. You should send her a link to this page and that ebay auction. Sometimes the truth is hard to swallow without some proof.
msmithmmx replied to biglittledog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe link for the OBW with a blown HG. Under 900 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=019&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=290133156595&rd=1&rd=1
