2
Everything posted by msmithmmx
I think I passed out!! When I put that fuse in place should the car be off or on? That additive is added into the transmission fluid filler pipe correct? Where can I get a funnel that is small enough to fit in there? And the big question? I have a box of ATF on my garage that has been sitting for 2 years (I put this job off) is it still good?
Dude, I am going to be honest I would not do what you are describing. First you are paying WAY to much for that car. I would say "free or up to 100 bucks. Your next problem is you have a 94, which translates into ALOT of extra work. A Sub Legacy Outback with a blown HD 96-98 with NO other issues I might pay 500 bucks
Been there, broke the head off of the Caliper mounting bolt which was not removed for 10 years. I spent 2 hours drilling it out. I did not have a tapping set to fix what I broke while drilling it out nor could I find a 17mm tap at any store. I spent 100 bucks on a new mounting bracket. Moral of the story, buy a impact gun off ebay and a new compressor at any home improvement store. If you are going to work on your car you need it.
Going to make this simple for you as I have done the 2.5 to 2.2 on a Legacy Outback. I used a 97 2.2. From the donor car (450 dollars tops) 1) Engine / use the exhaust manifold from the 2.2 donor 2) AC Compressor you must keep and hoses from your 2.5 mount onto the 2.2 3) Metal Power steering lines from the 2.5 move them over 4) The fly-wheel from the 2.5 will have to be moved over to the 2.2. From Subaru 1) All new exhaust gaskets (10 dollars) 2) new o-rings for the AC hoses you disconnect 3) new o-rings for the power steering lines you disconnect From Walmart 1) 2 cans of 12 oz refrigerant and a refill hose (30 bucks) While you are at it replace this on the 2.2 donor (100 bucks) an easy to do with the engine out. 1) Harmonic balancer (50 ebay) 2) AC and Alternator belts (20 pepboys) 3) Rear cam seal (5 dollars) 4) Oil Separator Plate (sure to be leaking, original is plastic) (15 dollars) 5) Rear main seal. (20 dollars) 6) Spark Plugs (10 dollars) 7) PCV Valve ( 8 dollars) 8) Valve cover gaskets (2 of these) and grommets for the bolts (30 dollars) 9) Reseal the oil-pan and replace both gaskets that are internal. (RTV temp sealer 4 bucks, gaskets are 10 bucks)
