Everything posted by ben--ny
Anyone done Dual Carbs with Webers or other>
dual bing carbs
Hows My Brat Coming?
good to here hows that motor running for ya??????
ea81t crank
gd, can ya put solid lifter and matching cam in a hydro block???
ea81t crank
gd, so the cam is the same too
ea81t crank
i'm looking for some help, is the ea81t crankshaft any stronger or different then a standard ea81??????
making a reliable ea81t
ok maybe i'm wrong here but useing commonsense here tubro takes 1300 egt throws it down the carb, supercharger takes takes ambient air and throws it it to the carb??? whitch is hotter
jon dont tubrocharge it, supercharge, it think about it, when you use a tubro you just dumping hot exhaust back in the motor to get hotter!!!!!!! know wonder the heads crack??? check this out www.rotrex.com
Sand Rail - time to go from VW to Subaru
ej2.2 wieghts in at 300lbs ready to run at 130hp ea81 80hp ready to run weight 175lbs 2.2 = 50hp more = 125lbs more in weight if it was me i'd skip 2.2 and go right to 2.5 weight in a 315lbs for the 15lbs in weight diff you get 35 more hps. if weighty matters ea81 if it don't 2.5
Subaru engined Trike.
thats great
Can we help you?
jon, nope looking for the whole motor this time
Can we help you?
tristan, i'm looking for a dual carb jdm ea81 got any???
mpfi ea81
i'm hoping to get strated on one myself soon
supercharged
anyone make a supercharger for ea81????
Heads in Portland OR
gd does that go for ea81T HEADS TOO
Exhaust done
hows the motor running more power with the duel port heasd??
ea81t is nearing completion.......
ross way to go ross glad it has worked out for ya!!!!!!!
Brat Swap.........
ej22 35 horses more it also weights 80 to 90 lbs more than a ea81 ???
Things maybe looking up finally.
wish ya best of luck with it
560cc injectors
nkx thanks
EA81-T upgrade
Mr Fishums if ya win the bid i have a full wiring harness and a ecu for the motor for ya
EA81-T upgrade
Mr Fishums it's me you've been bidding against baventurato
560cc injectors
what iis an evo injector the ones that go on a harley??
560cc injectors
wjm will they fit in a ea81t head???
Subaru Exhaust Question
shawn what kind of horse power did ron tell ya to expect???? ps if ya dont mind how much did the parts and the block work cost ya??
