Everything posted by WheaT_BeeR_MaN
wcss picture
try now? im not sure a better way. maybe some one can tell me how to post in here. oh click on the full size theyre big.
wierd problem
my clutch bearing is whinning and my engine is dying when i press the clutch in. ive never heard of it but i guess it makes since if its binding. maybe someone may have an answer?
wcss picture
good now. little cut and paste. damn it
wcss picture
hey i finally got around to putting a couple pictures together that werent big enough for my camera anyways. so i took 2 to later photoshop. i also took some people out in 1 of them. http://rides.webshots.com/album/555673928gKBbkV
Mark your calendars: SubieFest 06
just wanted to point out on the time attack u have n/a,2.0t and 2.5t. alota of us have 1.8t which as we know can beat a wrx. FYI
How much would you pay for a catless EA82 Y-pipe?
plus u want some back presure. y not make a few of each on a weekend and just have them. people will buy them for sure over time. im actully gonna make a mold of the center piece "83 or older" where the stereo goes and make it for a regular cd play and also with gauges or not plus a couple cig lighters. i would like to hear some more ideas about that as well not to high jack. i probably wont have time until after christmas since making money is important for the next couple months.
subaru demolition derby
i love it!!! on my subarus i by pass the fusible link for power.
Removing Oil Pump, EA81
actully i just did my first 1 yesterday on my 83. i had a little trouble getting that last bolt up on top. but anyways all i did was grab the filter and pulled back and forward with pressure out. im sure u tried this so im thinking use something else on the other side for leverage. good luck.
cheap tricks/tips for the hitachi carbs
i clogged my air filter full of mud and it caused it to stick open hitting 12000rpms a bunch of times. anyways we figuired out pretty easy when i took the air cleaner top off and it didnt do it any more.
rx with 6 speed?
makes sence. ya the 6 speed is much bigger and 100+lbs heavier then the rx's tranny. i was just so impressed with the difference with the upgrade in the wrx. id like to see what u come up with if anything.
rx with 6 speed?
SO IT WOULD BE A WASTE OF MONEY UNLESS I DO A SWAP. THX:banana:
rx with 6 speed?
well i just took a drive in my friend wrx that a 6 speed sti was put in, and man does it pull hard. its a jdm 6 speed which has a much better 5th and 6th gear. so anyways i was wondering if i could put 1 in my 88 rx turbo? would i have to change the rear end as well? then all the brakes and wheels? i just wondering cause it sounds like a good mod for it.
Built a hitch today.
you trust your bumper that much?i bent mine pretty easy.i think when u put a load on its probably gonna bend. but who knows till u try it.
550CC injectors: Cheap
sweet, good to know. id like to put some bigger injectors on my rx. thanks
Denver mad scientists - transmission lab: Lab ingredients/forumula FOUND!
already replace rear crossmember on a baja? we were thinking of getting a new turbo one.
88 rx turbo starting problems
well after putting some sea foam threw it new premium gas. its much better at high rpms sounds good but no idle. so anyways i decided to pull the plug and do a compression test and #4 has no compression so that would explain alot. im gonna put another head on it with the engine in the car. are there any sugestions to check or fix while i have the drivers side head off. this rx has less the 100,000 miles on too. pretty sweet huh.
corosion where? can i just put sea foam in the tank? or is there a better option.
well i dunno if you would call me having to use the gas to make it idle and heat up. it doesnt want to start unless i floor it. also i hear clicking around the intake manifold. we were thinking maybe a solinoid. i thought maybe the fuel injectors. i was wondering how i pour some sea foam down it? since it has the whole intake system will it run with it off while i pour it? or should i just pour the whole thing in the gas tank. i should mention it has sat for atleast a year. thanks for the responses:headbang:
nothing? no one?:-\
my 88 rx im trying to get home starts but only if floored and doesnt idle unless im pressing the gas.today checked the timing belts since it looked like some one replaced them. they were fine. replaced spark plugs and checked fuel filter flow "it was good" .well i searched around didnt find anything but some one talking about flooring it to start and it being a vacume leak. im hoping some one might have some ideas. oh and the other day i let it run for a little bit and i let it die and wouldnt start again even floored but it did sound like it made it difference when i floored it just didnt start. 88 rx turbo full time 4x4
Mud Bogs This Weekend!! PICTURES!!!!
atleast u didnt totally flake. it looks like u did a good job none the less. hey u should be buying your boss a beer for sure though.
4x4 vids from Perth Australia
i think my girlfriend is right were just a bunch of nerds. good video i watched it all.
Who has got a vanity plate 4 the oldsoob?
i like got90hp
Prepping Heads....
y not just spend a little money and take it to a machine shop to do the work and have them reseal the valves. plus take a couple mills off and gain some compression. then it comes back new as ever. also less work.
What If.....
thats freaking awesome. good score!
