Everything posted by Chris Rogers
Can we help you?
any luck on the XT6 bits?
Can we help you?
speaking to them now actually. why is everyone suprised when I say loyale + twin turbo
XT6 part numbers
does anyone have teh part numbers for the rear brake setup for a XT6. need everything on the rear as I'm doing a 5 stud swap and wish to buy most of it new.(yes I'm aware of the cost.)
BBS wheels! for OLD SCHOOL!
they are a special order. in my case I wnet to the factory when I lived in sydney. they still make them. send them an email with what you want. phone numbers are there also in your case 011 61-2-rest of number. allow 12-15 hrs for time difference if you ar going to ring them.
Paint code of L series White
that will do it. problem being that mine is a jap import. so I'm going to try both codes - 982 is probably the correct one though. ta!
Leaking GAS! (3.00$ a Gal.!!!) What is this part?
vibration damper. find another one. btw fuel here in Oz is 1.34/litre (4.625 L = 1 gallon) so we notice fuel drops more..
close. see also simmons wheels. specifically a P86. they made them in a gold mesh a few years back. about $2.5k with rubber for a 16x7" http://www.simmonswheels.com.au I think. I had a set on a L series turbo sedan for a while. best improvement ever for handling- went to a 17" for a bit but was too rough.
I'll go with 982 and 828. mine is white (as stated) but I really don't know what colour it is. think I'll send subaru Oz a email and attempt get the build sheet for mine. thanks guys!
1996 Subaru Leone?
depends. some of them have a 700cc S/C 4 pot in them consideringthey weigh 1200lbs they can move unloaded.
97 2.5L Engine Swap - What fits - If anything
if you can find them up there- twin turbo! EJ20R usually. depends on how much work you want to do. common in japan and about $2-3k here in oz. I picked mine up for $2k.
Suspension and 5 Lug Swap
could you clarify how much of the GC8 impreza front end I need please- is it the whole thing or parts thereof? are these the same as a 96 legacy GT?
Factory service manual for download?
those should be the same ones I sent you.
I'm not that lucky here. the paint shops want to know a code before they will mix it. I'm familar with what you are saying though.
any idea what the code is - my sticker has faded and I would like to paint the cars.
Full time front diff ratio?
3.7. mine was that. had a FT SR box in it (and yes I have a factory turbo L wagon in brissy.)
The Wonder Brumby
did you leave the SC14 switchable?
Radio adapter for 87 GL-10
anyone got the standard facia still. I'm after one (with brackets) from the electronic tuning version with a pocket.
no 3.9 ratio,s in oz
was 3.70 now 4.44.
More Vortex-XT Woes
almost sounds headgasket related. got a compression tester? should see 120psi or better on cranking.
speaker size
with a justy you can do 4" in the doors. the hole is inline withteh winder so they will have to be shallow or mounted behind the panel. I'll see if I can dig up a pic.
fwd to awd
better crawl under a AWD one. you need: rear end - complete, fuel tank, gearbox, shifter ,tailshaft, and all the brackets. electrics will line up and no need to screw with ECUs
Car Multi-sensor digital guage *added models & price ranges*
I'd be interested. this is for an L series correct? ( guy over here did it with a PIC and screen on nissan consult port. displays everything happening.)
