Everything posted by Uberoo
4x4 survival kit
spare parts of whatever is most likely to break.axles,timing belts,various sensors,etc.Spare lugnuts are also good.
ammo can ECU box.
the ammo box also is where the relays and ignition amplifier live.kinda hard to water proof those.
EJ22 swap help
yea they pulsed on and off, same with the light in the computer.They kept pulseing even after I unplugged the green connectors and turned the key to off.They quit when I pulled the fuse front the memory wire.
EJ22 swap help
it still wont start.I thought maybe that the choice in wires for start and run wasn't working so I checked them again.I can't find a wire that is 12V plus when I am cranking,the ones that have voltage are 8-9V.I can't even get the thing to pop.timing is right. even running the start wire directly off the small wire on the starter doesn't help.Pulled a spark plug and Im still not getting spark.
EJ22 swap help
so it looks like F47 14,B48 11,and B48 22 are supposed to be grounded.is that correct or is more needed?all three of those wires tap into a rather large bundle of grounds in the harness. so I added those three grounds now and once again my battery is complete crap..I need to fully charge it and see if its any good at all.
EJ22 swap help
it sill doesnt start but now I can smell gas.
EJ22 swap help
so I spliced a wire from constant 12 to the large yellow wires for relays same with the ecm wire 12V constant has hooked to originally,then a switched 12v wire from the light green relay to the other switched 12v.got it all hooked up.nothing in the car is soldered or in its proper place.gonna try turning it on and see what happens before I put everything in final.then my battery is junk.it charged all of yesterday,and it was disconected and its still flat.so its on a 50 amp start charge.in 30 minutes ill go out there and see if I can get this thing popping!from what I understand it should have 12V at all the right places(switched and constant).
ammo can ECU box.
I am doing a EJ22 swap on an 81 hatch.I had the ecu mounted where the spare tire used to sit inside an ammo box.got everything all together and I wouldn't start because there is no power to the ignition relay.While its apart I can change some things. originally to seal up the holes in the ammo box where the harness ran through I used lots of expanding foam.It would have worked just looked bad and was a real PITA the get the harness out.the harness came out the back of the box close to the firewall,so not that ugly but noticeable if you looked at it from the side.Anyway I am asking for any suggestions on how to seal the ammo box(at least enough to not leak for a couple minutes submerged).I know that subaru=/ submarine but when your offroading in tracks made by large trucks and your in something relatively small like a lifted Subaru-water tends to go over your hood..then if you get stuck in said hole
EJ22 swap help
ok got the harness out and partially stripped. constant hot just goes to B48 15. switched hot goes to the little yellow wire in the fuel pump relay and B58 12. all of the yellow wires from the ignition relay splices into a wire to the engine. the light green wire from the ignition relay goes into a wire splice that goes to F47 9 and the engine. the black ignition relay wire is grounded and is the only ground I have.
- EJ22 swap help
EJ22 swap help
I have no power whatso ever at the ignition relay on any wire.
Correct me if I'm wrong...
i put 2" blocks above my struts.the bolt holes were offset for camber. as for the trimming,if you look at stock fenders you will see where the fender flare meets the rest of the fender.I cut all that out.Then bashed in the floorboard until it was all a couple inches past the lower door hinge.after I was done I had to readjust the clutch for more travel and adjust the doors.. all hammering was done with a 10 lb hammer.` after I beat it out I ran with it for a while.Then I put ea82 front suspension under it for more travel.When I put the ea82 front suspension under it I also extended the radius rods 1.5" which moved the tire forward away from the foot well. the rear suspension was just cranked up. here is a picture of the thing before I put an 8" lift and a nissan transfer case under it. heres a pic when it still had the factory suspension.the tire went flat because alot of debris got into the bead after playing.you can still see how close the tire was to door.
EJ22 swap help
ob1 91 intake manifold,wiring harness and ecu.
EJ-22 swap, Project Loyale
looks great,my only concern is the D rings on the rear bumper arn't meant for recovery just for tie downs.I don't know if you have had to use them yet,but I thought I would throw that out.For recovery you want shackles mounted as securely as possible to something solid. either type will work but you can use more weld to mount the shackles than you can with the d ring.
Extending steering shaft
im not a fan of rag joints,mainly because the effort of turning my 31's was tearing the rag joint a little..that and I like steering precision.
EJ22 swap help
ok so I try to start it after I have everything hooked up and it didnt start.pulled a spark plug and no spark so that tells me the computer is somehow not getting voltage.So I got out my my multimeter and started checking for voltage.I have voltage at the constant hot wire for the computer,when the ignition is switched on I have voltage to the wires that is supposed to be hot in run and start,and I have voltage to the start wire,BUT I HAVE NO VOLTAGE to the the ignition relay. is there something Ive missed?the harness and ECU came out of a running car.Any ideas on where to check before I unsolder all the connections the harness has to car and lay out everything on my floor and start again? there is power all the way up to the original yellow wire splice that that should be hot in start or run from there one wire goes toward to engine to power up that part of the harness and the other one goes to computer to power it on.even if the memory wire for the computer wasnt connected it should still start and run. if anything there is only one wire attached permanently to car,everything else has connectors..except that wire requires taking apart the dash.
EJ22 swap help
I am putting the finishing touches on my 81 EJ22 hatch.Right now my only concern is the return line.I know on the engine the reline line is the one that feeds into the pressure regulator.my problem comes with the car itself.the car originally had a computer controlled EA71,so the return line is very small,like 1/8" inside diameter.I am wondering if that will flow enough to return the fuel from the ej22?
Muddin in the odd ball
from your exhaust it looks like some water is either getting in the exhaust or the engine.Double check all your connections just be be sure intake and exhaust.
Scoobie stack pt.2 UEL header
needs MOAR flapper.
Walker Pics 02/25/2012
aw you dont NEED taillights so its all good.
depending on how much you want to massage the fenderwells, I fit 235/75/15's on my 2" lifted EA81..
First time off roading my Forester
how come you didn't have a skidplate? thats mandatory for offroad.Heck around here its mandatory on the street.
- Walker Pics 02/25/2012
Wagonstien taking fully independent suspension to the next level
have you test fitted the tire size you want yet?Looks like alot of your uptravel will be killed by the tires binding up in the wheel wells. on my EA81 with 8" of lift and 31's I can only stuff the tires so far into the wheelwells before they bind up.nowhere near the max angle of the CV's.Thats for the rear.the front is limited by the 6" travel ea82 struts... also what EJ car are the front axles for?
Ford tempo spring swap help! Ea82
your tempo springs might be different,but I had to cut a coil off just to even get them into the strut.the coil you want is NOT progressive BTW.
