SevenSisters
Everything posted by SevenSisters
According to Subaru, it's not a "flasher", it's a "Turn Signal and Hazard Unit". (love those engineers). My manual says to remove the glove box and then the glove box frame. Disconect the unit connector and remove three screws that hold it to some bracket. It's in there someplace next to the Illumination Control Unit. Sorry I haven't done this repair so I can't vouch for the directions. Doesn't look like the typical flasher can from the poor illustration.
If you're going to do the job, you may as well go the extra mile. When you push in the piston, open the bleeder screw and bleed out the xs fluid at the wheel. DON"T PUSH IT UP into the system and ruin a $1000 ABS pump. When you're done cleaning up and lubricating what should be lubed, don't just bleed the brakes, replace all the fluid by bleeding, adding, bleeding, adding, etc. ALL WHEELS. Don't let moisture contaminated fluid ruin a $1000 ABS pump, valve body.or calipers. Good Luck.
Sounds like a flawed component in the secondary high voltage circuit. Start by using a hair dryer to dry off the spark plug wires, coil, and igniter. Some people might use WD40 (water displacent, 40th try) to accomplish the drying. See if it will start then.If it does, lightly mist all the components with water in a dark area and look for any arcing. This should lead you to what's wrong. Most likely just the plug wires, maybe a cracked coil pack. Everyone have a good Easter!
Here's what happens. Subaru puts on a good handling tire at the factory and puts in a 130 mph speedometer to let you know you have a high performance sports car. When replacement time comes, people don't want to spend the money for H speed rated tires and say they don't drive 130 mph anyway. The tire dealer puts on T's rather than loose the sale. The car owner doesn't keep air in them and one blows out at 50 mph when they're drunk and causes an injury. Some lawyer says the car was designed to go 130 mph and the dealer is a tire expert and should have put back on H rated tires.So, the dealer and tire maker get sued and pass on the cost to other tire buyers. Everyone is now happy. Some states (Maine for example) either have laws or want laws to make people put on the same tire size and speed rating. (got to protect the voters). Better profits for the tire guys by the way. Other dealers may make you sign a waiver if you want lower speed rated tires. In my opinion, the bottom line is you won't get the same high performance traction rating (AA) and the handling won't be as crisp. The average driver won't notice it and will be happly with the greatly improved treadwear. Learn about traction, temperature, and treadwear ratings and look at several websites and Consumer's Reports for good recommendations. Keep air in your tires. My '91 2.2 130 hp came with H rated tires. Subaru give me a break. Hard for this car to get out of its own way.
I was just stating my opnion which is held by at least a few other people. I could have bad mouthed the 500, or the Potenza, or talked about all the people that died in their Firestone/Bridgestone Explorers. But I didn't. Just because you don't like 'em, doesn't make Tire Rack, CReports, and everyone else wrong. Try the Triple Tread and see what you think. Everyone else seems to like them according to the feed back I read and dealers I've talked with.
