Everything posted by myles
In the case of the external leak (water jacket to outside), the "goo" has to stand up against the pressure differential between the cooling system and the atmosphere. For an internal leak (cylinder to water jacket and vice versa), the "goo" has to withstand the pressure differential between the cylinder and the cooling system.
Knock sensor
myles replied to CJK440's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Why not download the FSM's from http://techinfo.subaru.com/ for US$20? It's a bit tedious, but they're (obviously) far more accurate than the aftermarket books. Also, tighten to the specified torque (as specified by Subaru, not Haynes ). -
What engine's in this beast? In my car, a 2002 Legacy GT with the single-cam 2.5l, it would be easy to do with the engine in the car. Removing the battery, washer bottle, and intake duct work makes for plenty of room to get at the valve covers. I think cars with the twin-cam engines (be they 2, 2.2, or 2.5 litre) have less room between the valve covers and frame rails.
Binding issue
myles replied to hawksoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The fact that the viscous unit is _not_ serviceable is spelled out in the factory service manuals :-) -
Binding issue
In the North American market, _all_ Subarus with manual transmissions, except the WRX STI, have a center differential with a viscous limited-slip unit. Some also have LSD's on the rear axle. Think of it this way: your center differential is built like a normal, open differential, but the shafts that transmit torque to the front and rear axles are joined together by the viscous coupling. When one shaft is turning considerably faster than the other, the silicone fluid (that's sealed inside) will begin to shear and heat up. The properties of this fluid are such that it becomes more viscous with increasing temperature. This "locks" the two shafts together (for suitably generous definitions of "lock"). -
Binding issue
Do the viscous limited slips typically fail "locked", or "open"? I wonder how many of us are driving around with "open" diffs w/out realizing it. -
Binding issue
The viscous limited slip unit is _sealed_, repeat, _sealed_. If/when it breaks, you replace it. There's no way to add anything to the silcone fluid inside. -
Let's see. My MY2002 Legacy GT (manual transmission) weighs in at about 3345lb and has an engine that develops 165hp. It gets 21 mi/US gal around town and 27 on the highway. How do these fuel economy figures stack up against other vehicles of similar mass, with engines of similar output? In other words, I don't think the AWD drivetrain hurts you all that much (and as another poster mentioned, your auto. trans. sents most of the torque to the front most of the time, anyway).
It's easily accessed from the engine compartment. To drain, remove the dipstick and drain plug. To fill, use a long, slender funnel that'll fit in the dip stick tube. As far as lubricants go, you'll be safe with the OEM stuff. Perhaps others will comment on their experiences with other brands. I'm considering Mobil1 75W90, but I worry that it might lubricate _too_ well for proper syncro. operation.
