Everything posted by myles
really newbiwe ?
myles replied to sho's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Eye thinc itz inn thee passengur futwell. -
JDM Headlights
myles replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
When and where are you going to use strobe lights? -
My 2002 Legacy GT has been noisy when cold since new. I'm not sure if it's piston slap or a noisy timing belt tensioner. I'm more inclined to think it's the latter, as it doesn't sound "metallic" enough to be piston slap. How's this for an experiment? Place a lightbulb, or some other heat source, against the timing belt cover, near where the tensioner is. Leave it overnight. Ideally, this would warm the tensioner without warming the block considerably. No noise = failed tensioner, noise =, well, you get the idea.
tires
myles replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I've not heard of that brand, but I highly recommend the Continental ContiExtremeContact. They're about US$80 a piece at Tire Tack. -
There's really nothing unique about Subaru clutch replacement. There's more work involved to get access to the clutch due to the AWD, however. How high can you lift the car? This will determine whether it's easier to drop the trans. or pull the engine. If you can raise the car a few feet off the ground, I'd drop the trans. It'll be faster than removing and reinstalling the engine plumbing/electricals (which may be more complicated than those of my naturally-aspirated engine).
You're going to have to change the plugs eventually, no matter the condition of the threads. Assuming the threads turn out to be OK, tighten the plugs to 15 ft-lb (12 ft-lb if you put oil on the threads). Tighten the lug nuts to 58-72 ft-lb. It's best (and recommended in the factory service manual) to tighten in 2-3 steps.
Torque Wrench
myles replied to danz75's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I own Husky and Craftsman click-type torque wrenches. They're not terribly expensive, and "good (accurate) enough for government work". As another poster mentioned, in most cases, precision is more important than accuracy. I'm nothing more than a "shade tree" mechanic, but I _always_ use a torque wrench when installing spark plugs and tightening lug nuts. The wrenches are _much_ cheaper than replacement brake rotors and cylinder heads. -
That's right, you're in Westchester, right? I had a brain fart for a moment and thought Brewster was in western NY. I suspect retail's a bit higher the closer to NYC you get (compared to the Capital District). I paid about 21k for my '02 GT. Personally, I wouldn't pay a dealer more than $15.5k for a car like mine ('02 GT, manual trans., 6-disc changer, ~30000mi).
