3
Everything posted by porcupine73
Hm..interesting idea! The Subaru water pump is probably more like 20-40 GPM (gallons per minute) (depending on rpm, etc), equivalent to 1200 to 2400 gallons per hour (GPH). SummitRacing.com sells many electric water pumps in the 20-40gpm range, those might work. Some are just electric motors intended to drive the existing water pump; some are pump and motor in one unit. These appear to commonly used for drag cars. I think you would need to run the water pump all the time though, even during warm up. The coolant still circulates through the heater core and throttle body when the thermostat is closed. The thermostat needs this flow so that it can tell when the coolant has reached sufficent temperature to open. Plus the localized overheating potential without the pump running.
Sounds like you've got these ones covered, but from http://endwrench.com/images/pdfs/2.2Liter.pdf is: 2.2 Liter Engine Enhancements Beginning in the 1997 Model Year, the 2.2 liter engine for 1997 Legacy and Impreza models has had internal and external changes that yield an approximately 10% increase in power and 3% increase in fuel economy. Accomplishing this involves many factors, one of which is engine friction reduction. The piston, a major source of engine friction, has been coated with a friction reducing agent called Molybenum. This thin coating not only allows smoother travel through the cylinder, but also reduces cylinder wall scuffing. The skirt of the piston has been reshaped and the overall weight has been reduced by approximately 100 grams. Compression ratio has been increased to 9.7 to 1 by reshaping the crown of the piston. This eliminates the clearance that was available between the piston at TDC and the fully opened valve. Piston pin offset has been changed to 0.5 mm. Piston to cylinder wall clearance has been reduced by increasing the piston diameter. Another source of high engine friction is the valve train. Hydraulic lash adjusters (HLAs) are always in contact with the valves. The hydraulic pressure of the lash adjuster must be overcome during operation and during the most critical time of engine start. To overcome this situation and to contribute to the total reduction of friction loss, 1997 and later SOHC engines have solid valve adjusters. The scheduled service of this valve train is set at 100,000 miles. SOHC engines now use an adjustment screw to adjust valve clearance.
Oh sorry here it is before i opened it. Someone was dutch auctioning 10 or 15 at the time. I think they were like $8 ea. in that auction. I haven't used it yet, but am hoping it will work well for the cam seals. They are always a pain to get out for me and I usually end up scratching the cam in the process. Subaru oem part #'s I usuaally look up at http://www.subarupartsforyou.com
tire size
porcupine73 replied to aartod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Hi. Take a look at the clearance between your strut lower spring seats and the top of the tires. Often this is a limiting factor. For wider tires, often wider tires will fit but may give rubbing in the turns in the front. -
Hi. Just for reference here's the Subaru part #'s anyway. Looks like these are all ~$300 from subaru dealers selling online. 45111GA570 RADIATOR ASSEMBLY FOR 1985-1987 XT COUPE 1.8 WITH MANUAL TRANS ONLY 45111GA580 RADIATOR ASSEMBLY FOR 1985-1987 XT COUPE 1.8 WITH AUTO TRANS ONLY 45181GA610 RADIATOR ASSEMBLY FOR 1988-1991 XT GL COUPE 1.8 WITH AUTO TRANS (NON-TURBO) 45181GA350 RADIATOR ASSEMBLY FOR 1988-1991 XT6 COUPE 2700 WITH MANUAL TRANS ONLY 45181GA361 RADIATOR ASSEMBLY FOR 1988-1991 XT6 2700 WITH AUTO TRANS ONLY
Thanks for the clarification about the oil separator not really being related to the rear main seal. I'm not sure where I got that idea from... For the front crank seal on the oil pump, I always (well ok the two times I have done it) installed the seal on the pump while it was out. I put some grease on the oil seal lip and crank snout before reinstalling and didn't have any problems with the lip folding over. I find it much easier to get seals to go in straight when there's not a snout in the way. I find the cam seal a pain and usually mess up at least one when putting the new ones in. Maybe I should take rad out when doing it next time. Not completely sure on the matching up of the '97 forester to impreza rear wheel bearing housings. The part #'s are the same, but it says Forester '98-'00 and didn't show '97 forester part # 28411AA000 HOUSING, REAR AXLE RIGHT FOR 1993-2000 IMPREZAS ALL 28411AA000 HOUSING, REAR AXLE RIGHT FOR 1998-2000 FORESTERS ALL 28411AA010 HOUSING, REAR AXLE LEFT FOR 1993-2000 IMPREZAS ALL 28411AA010 HOUSING, REAR AXLE LEFT FOR 1998-2000 FORESTERS ALL
I have used some PVC caps from the hardware store to fit over the cams and then use a hammer to tap in the seal using the a hammer on the cap. For pulling the seals, I find this a major pain even with drilling holes etc in the sales. I recently bought this puller (but haven't used it yet) supposed to work pretty well: Subaru approves the use of permatex ultra-grey for oil pump sealing. Any reasonable size chunk of the rtv will be caught in the engine oil filter, since the oil goes through the oil filter after leaving the oil pump discharge (the part sealed with the o-ring to the block).
Here's some common soob oil leak locations: Here are the most common Subaru oil leak locations with pics: Front cam seals (especially the earlier black colored seals; the newer brownish colored ones hold up better) (pics from an EJ22): Front crank seal (esp the mid 90's 2.2L's and some others where the screws on the rear case of the oil pump tended to loosen, letting oil out the front crank seal and sometimes even pushing the seal right out) Also there is an o-ring between the oil pump discharge and block The valve cover gaskets, and for engines where the spark plug tubes penetrate the valve cover, the spark plug hole seals. EJ22's also have an o-ring at the LH rear and RH front of the cam's: Also rear main seal, especially if the vehicle had a plastic rear main seal retainer/oil separator (an OEM upgrade to a metal retainer is available).
hehe yah I 'd say we move on and build a prototype of the proposed unit! wohoo. Maybe we can parallel ten of the new soob 3.6L's to get us started. Yes for the peak power loading I remember ten years ago on co-op standing next to a 39000 hp air compressor firing up, they had to call the power co for permission to start it first, and said it was ~$1000 just to start it.
Harbor freight sells small generators powered by SUBARU engines Yes also typically engine must be a bit overside for the generator. Otherwise it cannot react very quickly to a sudden change in load. A good generator maybe has ~97% efficiency? But that would be on a larger scale, like the big ones you guys are talking about? Larger units will also possibly be synchronous generator setups, which can also help match power factor of the load. However such generator rental is becoming more popular in areas with rolling outages during peak demand times since co's consuming lots 'o power can get a much better rate on interruptible power. Also now in many areas power co's are not allowed to interrupt residential power until all power contracts using interruptible power have been excercised. i.e. maybe your contact with power co is for 30 minute interruptible power, which means power co can call you at any time and say in 30 minutes you have to drop all your load, except maybe some negligible office/lighting power. Then you have agreement with a generator rental co who comes out and ties in their generator to your switchgear/motor control and you are back online!
Hi. Yes not sure. It must have to do with economics. Like truck + generator as two separate efficient items means a profitable product. The custom truck you mention with a hydrid drive would cost wayyyy more than the two separately mated together. Plus it would not be as efficient, i.e. diesel -> drivetrain diesel -> generator -> electric motor -> drivetrain is not as efficient.
