Everything posted by WRX1AB
you've got to see thi one
hahaha, hye shan, rocky from canyon sent it to me too! its the ultimate 4 wheel drive
98 Legacy 2.2 Oil Leak
WRX1AB replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXall the above, and busted cv boots make nastey smell when stopped.
Does this sound like a headgasket prob
WRX1AB replied to nicecj7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit sounds like air needs to be bled out of the system
hte ultimate 4 wheel drive
if soneone didn't alrady post it..... http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2467472903&category=6467
legacy impreza cv joint interchangable?
WRX1AB replied to WRX1AB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDave, can you also check the range on legacy frive shafts? I ahve a 92, it looks like the 96's will fit too. can you confirm (or deny) How are you doing anyway? How was the snow? I found a '93 legacy in a yard with little rust, and got only one axcel. It has been rebuilt once and needs boots, and I also got a caliper all for pretty cheap. I couldn't get the roll pins out of the 96 because of a lacking of tools and extensions, and winter green penatrating oil. And I don't have a blow torch. (we need a smily face with gogles and a blow torch)
OK lissenup, I am ready to pronounce an assessment on the SOA
WRX1AB replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsubaru has been making aluminum block aluminum head cars for a long time and does infact know exactly how to make them. they must have forgotten. You should all remind them with a class action lawsuit.
what is says... Is it? I have a 92 legacy, needs rebuilds, no-one has them where I live (UK) and imprezas are a dime a dozon 9or cheaper) don't make me get them shipped rebuilt from the US! 92 legacy 2.2
Drive shaft interchangeability
WRX1AB replied to WRX1AB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXand thanks for the general year placement!
WRX1AB replied to WRX1AB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXunfortunately I am in hte UK, and in hte north (newcastle) and GOOD parts stores are in short supply. Subes are rare here. which is a bummer. I was going to get axels and rebuild them myself with new boots, then use mine as cores for a new pair when I need them And have the time and money to replace them
WRX1AB replied to WRX1AB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso what I forgot to say was that it is my only mode of transport and I need to get shafts soon. I am assuming that 92-92 legacy shafts will fit. any other years?
WRX1AB replied to WRX1AB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
timing belt tools
I didn't ahve a vice, so I compressed the tensioner between the house's brick overhang and the car jack. any other cool tricks?
I need drive shafts and I am going to a wrecking yard soon. I have a 92 legacy awd, and the fronts are so bad that it sounds like heard of clydesdales. If I yank accels and a brake caliper, what years are interchangeable (also has ABS)?
It was supposed to be just a timing belt
WRX1AB replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow, all taht stuf was fine on my 92 anbd its got 124000miles on it.
Timing Belt: Tools Required?
WRX1AB replied to WRX1AB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwoops its a 92 2.2 legacy 5speed 4x4 (not that it matters too much). hte bolt does look to be about the same as my ea81t (that was the wrx want to be. I used to be on the older gen site. I built a fulltime5 speed pushrod turbo dl wagon taht would destroy everything off the line in low range for the first 5o feet) I measured the bolt before I left and you are right. my favorite trick was to put the breaker bar between the ground and the skid plate and put the socket on the nut and .......................... turn the key. hte starter has way more torque than my little arms. check rotation directionfirst!!!! anyway, thanks or the advice. I ahve no ac, so it looks to be a peice of cake. I also have no money and because it looks easy, I will skip the water pump and seals for now (well, maybe i will do the crank seal) and do them wehn I ahve more cash. I also need to do front drive shafts and my y pipe is leaking, so a little at a time.
I have no tools and want to spend as little as possible. I am an experienced mechanic. Can you tell me the sizes of the crank pully bolt? I am assuming 10, 12, 14 17 and 19 for everything else. Am I going to need a balancer puller to get off the pully? Is it standard opperating proceedure to do teh water pump at teh same time as the timing belt?
Justy tranny q's
actually dave, I have no itnentiuons of messing with this one. its a 2.2 legacyt, so it can ctually get out of its own way. and it is already fuel ink\jected so I don't have to do that either. it is a sube though, so the y pipe needs welding and the drive sahfts are ****ed.
Justy tranny q's
gday! thanks for the reply. I gave up on the ratty rusty justy and just slapped 500 gbp (sterling) on a 92 legacy sedan 2.0 injected, 4x4, abs and power stearing. needs a t-belt, axel boots and some cranc seals seals and a clutch adjustment. So, I guess I am moving to the newer generation section
Justy tranny q's
Hey fellas! any ideas on the justy tranny? Like I said, the dude who owns it said the clutch brushes go bad, but I ahve heard bad things on other sites about it just failing. could it be the brushes and nothing else? PS is it half a sux six banger? the valve covers look like regualr sube issue ea82
Unidentified EA81T part....
it might be the sensor that hooks to the dash aqnd lits up at 2 lbs with the green "turbo" lite. give a picture and I can ID it
Justy tranny q's
pardon me , but bump!
Justy tranny q's
well, dave, thats kind of what I was thinking. I was looking for more techy help though. I just checked out the car(s) and the owner says that the brushes on hte electromagnetic cluth are what take them out. However, this thing has quits a bit of rear wheel arch rust. there is antoehr one I am checking out that has much less rust ans is a 5 speed, but it is not white and it does not have a sun roof and is only a two door hatch. it looks like the motor is half a 6 cylinder. is that right? And thaks DAve! how is the skiiing??? God I miss it, and I miss the beasstie, and I am glad dave got to see it! that was a fun FAST car with GREAT breaks. I even scared myself with it!
Justy tranny q's
Some of you may rememebr me as the guy that put the injected turbo motor and fulltime 5speed in an old ea81 dl. well, I am sick of hoofing it here in england, and I ahve tracked down an interestind deal on three justies for 400 pounds. the nice one is ECVT tranny, then next one is a ratty bod with a 5 speed, and the third turd is parts only. dude says the ECVT is fresh rebuild, but I am hearing bad things, and I ahve abad case of lead foot. I don't have any tools here so a tranny swap might be an option later, but certainyl not right away. just how crappy is the ECVT and (I am not even going to ask how hard the swap is because thats my speciality) how good is the 5speed? shout out to shansf and brian and turbosoob
Help me figure out this Odd Cooling Issue
any leak in the coolant will not only allow coolant out, but air in upon cooling. any air in the system can get re trapped. that will cause all your problems. My ea81 t was experiencing the same problems, unfortunately I never found the leak, but shansf has it now, and I bet its in teh intake manifold
Ford 2300 Carbs
I had a 2300 mustang3 turbo first generation (not svo). turbo sucked through the carb, was jetted way too lean form factory. that carb is really easy to rebuild and has very few moving parts. Also, whilst at a pull it your self yard, yank the jets out of a bunch of different fordsds, (trucks, pintos, mustangs, capris) and you have an instant jet kit for tuning. the kit we swiped made overboost possible and for a few miles, we were killing 302's and svo's. and we were OK with that.
